DSC Malfunction!
01-17-2011, 05:11 PM | #1 |
Rep 538
DSC Malfunction!
Last night, I slid on the road and hit a curb goin about 25, just a scratch on my bumper and the alignment is messed up. I was driving today and the DSC malfunction light came on. How much could this cost to fix?? and what can be the problem?
01-18-2011, 08:22 AM | #2 |
Rep 3,957
Going to cost more than you think. You will probably need to make an insurance claim.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
01-18-2011, 08:25 AM | #3 |
Rep 160
Hard to say how much this will cost...
My guess is you did some minor suspension damage when you hit that curb, and the DSC is having difficulty because of the mis-alignment of the wheels. If you damaged the lower control arms you should be able to get everything fixed for under 1k - even at a dealer.
Just my $.02 -Tom |
01-18-2011, 08:40 AM | #4 |
Rep 7,089
Drives: '06 AW 330xi
Yea the DSC error is a result of your mis alignment. I wouldn't say it's just your control arms but I would NOT keep driving your car like this.
You can further stress other components and damage more than what was originally bent/broken. |
01-18-2011, 02:54 PM | #6 |
Rep 3,957
Not a pain, just expensive.
01-18-2011, 03:00 PM | #7 |
Rep 3,012
I'll bet money that you bent a tie rod. Bent tie rod = misalignment = DSC error. If the car can not calculate which way your wheels are turned then it throws its stability correction algorithm for a loop and you get the error. Tie rod replacement is a DIY job. Replace the tie ride, measure the number of threads showing on the opposite side, then take it in for alignment.
01-20-2011, 01:19 PM | #9 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
You're assuming it's just the tie-rods.
Depending on how much is messed up, this can cost as little as a couple hundred, but if your description is correct, I've got to assume it's going to require replacing MORE than just the tie-rods. The tie-rods are made of high tensile strength steel. The upper and lower control arms are made of aluminum. those will bend long before the tie-rods bend. Meaning that if you have tie-rod damage as suspected, at least one of your control arms are bent too. If this cost less than $800 to fix I would be surprised.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
01-20-2011, 01:51 PM | #10 |
Rep 160
I posted this on a similar thread, but I think it still applies...
In my e39 5er I slid on ice into a curb - probably about 20MPH. It knocked the alignment out and required I replace some lower suspension components. The work was completed by my local indy shop with BMW parts for less than $500.
As an example for cost, the BMW sourced M3 front control arm kit (something I am drooling over quite heavily) is available from HP Autowerks for $443.99 http://www.hpashop.com/product.sc?pr...categoryId=175. Real OEM lists the parts for the e90 (non M) at $236.08. Go get it checked out. You will have to pay to fix this, but it shouldn't be through the nose. -Tom |
01-20-2011, 02:00 PM | #11 | |
1821
Rep 5,337
PLUS, there are a lot of variables with regards to what is and is not damaged. I still stand by my statement that if the repairs come out for less than $800 I will be SHOCKED.
01-20-2011, 06:50 PM | #12 |
Rep 402
Tischer has pretty good prices. I replaced all my tie rods, control arms, tension arms, stabilizer links, etc. on my xi and I think it came to about $800 or so. And it's a total DIY project. Not hard at all. To remove and replace all components shouldn't take more than 4 hours total. Hardest part is getting the TRE out of the knuckle, IIRC. I think, though not sure, you can get the "old" performance suspension from Tischer for about $400 and it includes tensions struts and control arms and bushings. http://www.trademotion.com/partlocat...catalogid=4462
01-20-2011, 07:30 PM | #13 |
Rep 941
damn! 5 more mph and you would have flipped it!!!!
http://www.e90post.com/forums/showthread.php?t=477838 |
01-20-2011, 11:38 PM | #14 |
Rep 1,465
02-02-2011, 10:47 AM | #15 |
Rep 538
I ended up taking it to a shop and had it inspected!! Nothing bent or broken! got an alignment and about 20min later, the dsc light turned off!! I'm soooo lucky=)
02-02-2011, 12:45 PM | #16 | |
Rep 7,089
I had $1500 worth of damage sliding into a curb at 25mph....wheel bearing and control arm had to be replaced as well as a few other components. |
02-03-2011, 12:10 PM | #17 |
Rep 3,957
It's not right. There will be problems later.
