Ticking sound inside cabin of 2011 e93 - is it a bomb?
01-21-2011, 03:59 AM | #1 |
Rep 532
Purchased car new in October. 335i e93
The ticking happens even when the engine is off, but the ignition must be on. The ticking is in sync with a clock, but at 2x the speed. SO every other tick is a second. It is very noticeable even while driving. I searched the heck out of the car and just cannot pinpoint where its coming from...but seems towards the back of the cabin tick tock tick tock..... boom? |
01-21-2011, 05:07 AM | #2 |
Rep 227
Drives: 2011 e93 335i
I have the same car and same year (2011). I have not heard the ticking noise you are talking about, but the car does have a surprising number of annoying squeaks and creaks (all occur when going over your usual bumps in the road). Seems the build quality is not what you would expect from a $60k car. Case in point: push on the center dash area (right above the temperature display area). See how much give it has, and how much it creaks when you push on it? This was true of all the brand new 3 series I checked out at the dealer. The same creaking occurs when going over bumps (at least it did in my car).
So your ticking noise is coming from the rear seat area? And it occurs very regularly, like a clock? How loud is it? If all else fails, I would take it back to the dealer to have it checked out. I've already had mine back to take care of that creaking issue I described; they said they put some felt tape behind the console to decrease the give. It still creaks when you push it but at least I don't notice it as much when going over bumps now. I could go into detail describing various other annoying noises the car makes, but I'll probably just start a new thread about it. Sorry to digress... I just had to rant a bit. |
01-21-2011, 06:22 AM | #3 |
Rep 2,189
turn blower to vents off... ?
are you sure its from inside the cabin and not engine compartment ? does it happen when the car is cold, hot , or all the time ? please remove CD and nav disc if you have both and see if it continues. and i must ask... are you sure your turn signal isnt on ... LOL ppp
Olds Starfire > Chevy Malibu > Isuzu I-mark RS & Honda Magna 500 > Grand Am GT & YSR50 > Nissan Maxima & Ninja 750 > X-Wife > Hyundai Excel > Honda Prelude > Honda Accord > Honda Prelude & Ninja 250> Infiniti G35 > E90 335i > Hyundai Genesis Rspec, Hyunadai Sonata > Kia Sorento > Honda CRV-EX |
01-21-2011, 06:35 AM | #4 |
Rep 38
Drives: 2011 335is sapphire black
Interesting. I have a 2011 335is and I have no creaking, squeaking, ticking, etc. I'm thrilled with the build quality, across the board. I wonder if it has something to do with convertible vs hardtop....
2011 335is Sapphire Black/Black 6sp MT 269-style 19" rims Convenience/Cold Weather/Premium/HK Sound/iPod |
01-21-2011, 06:42 AM | #5 |
Rep 227
Maybe...or maybe it's just the luck of the draw. Mind you the noises I hear are rather subtle and I can rather easily drown them out by turning up the stereo system to even moderate levels. So have you turned off the radio and really listened to the car, especially on bumpy roads?
01-21-2011, 06:48 AM | #6 | |
Rep 38
01-21-2011, 07:32 AM | #7 | |
Rep 2,132
01-21-2011, 09:24 AM | #8 | |
Rep 227
In any case, point taken. At its heart it's a 3 series, so I guess one should expect 3 series build quality, whatever that is. Still, it's a BMW, and I would expect build quality for a BMW to be very high. If you do a search, you'll see many posts about various creaks and squeaks and such and the extreme measures that people will go through to get rid of them. I would like to think that this is just a vocal minority, and that this is just the result of variations in build quality. Luckily, I may be in the "high build quality" camp. I just took my car for a late night spin, and lo and behold she seems to be essentially free of any significant unwanted noises. The main noise that was there was a creaking noise that seemed to be emanating from the right rear passenger seating area. Well, I removed everything from my trunk, and the noise seems to be gone now (knock on wood). Sorry to have gone a bit off topic skimo, but based on my experience, I think you should do the following: 1. Since you mentioned the noise was coming from the rear of the cabin, sit in the back seat to try and localize the sound. 2. Remove EVERYTHING from your rear seats and trunk. Check underneath the trunk to make sure there aren't any loose items lying around. 3. Now check for the noise again. You mentioned that the noise was tied to your ignition, so it's less likely that something in the trunk was causing it. Still, it's worth a shot. Who knows, you might find a clock lying around back there If all else fails, just take it back to the dealer. Since the noise is easily reproducible, they shouldn't have any trouble figuring out what it is. EDIT: Sorry, I just realized you mentioned you already checked your car thoroughly. Try removing all the stuff if you haven't already done so; can't hurt. Also, has this sound been there since you bought the vehicle? Last edited by ww007; 01-21-2011 at 09:29 AM.. Reason: Re-read your post |
01-21-2011, 09:27 AM | #9 |
Rep 113
I had a horribly annoying rear deck creak that has been posted here before by some people. I would hear a ticking, creaking, or whatever noise you want to call it coming from the rear deck. Over and over. Warm or cold. Flat road or bumps. It was driving me insane. I jammed some 5/16" vacuum tubing into the crease of the rear window and the deck, really jammed in in there good with a flathead screwdriver, NOISE GONE!
01-21-2011, 09:53 AM | #10 |
Rep 6,604
Drives: e92 335i
normal
01-21-2011, 12:26 PM | #12 | |
Rep 7,089
Drives: '06 AW 330xi
It does not have to indicate the base price for a model. It provides a number as to what an average consumer would want in the model.....basics. Such as power windows or seats etc. Yes I know....nowadays these "features" are standard. But they are still options. These are common options people choose and this is what determines an MSRP value. |
01-21-2011, 12:29 PM | #13 |
Rep 2,982
Um. Convertibles always have a lot of creaks and more so as they age. So many moving parts and seams that all move with every flex of the chassis. My car has not a single squeek or creak. But I'm only at 8k miles so far.
01-21-2011, 12:55 PM | #14 | |
Rep 2,132
01-21-2011, 12:59 PM | #16 |
Rep 2,189
a base 7 series would be better then a loaded 5 series... for example... and cheaper.
so ?
01-21-2011, 03:11 PM | #17 |
Rep 532
Just to clarify...
the sound is not a "squeeking or cracking' or any sound related to loose parts..its a very mechanical and persistent sound. Sounds EXACTLY like a clock ticking... I honestly thought someone left a watch or something behind, but since it only happens when the car has power, I am guessing its part of the vehicle. This is very strange its going at the pace of a real clock. I will continue to search for it. |
01-21-2011, 04:47 PM | #18 |
Rep 35
i can relate to these posts, unfortunatly, i have a unbeleivable annoying noise when the top is down and the rear drivers side windows makes an annoying creeking sound, it goes away when u put the window down. brought it to service twice and they still dont know how to get rid of it. i really was expecting better build, but the SA told me to expect some sounds being that it was a convertible and advised me to take advantage of the harmon kardon system i have and tune up the stereo. lol
01-21-2011, 04:56 PM | #19 | |
Rep 227
01-21-2011, 05:01 PM | #20 | |
Rep 227
01-21-2011, 05:18 PM | #21 |
Moderator
618
Rep 10,858
Get out of your car -- NOW!!!
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
