Door not unlocking
02-23-2007, 10:54 AM | #1 |
Rep 64
Door not unlocking
Ran a search to no avail....
My drivers side door stopped unlocking It locks fine but won't unlock with the keyfob or dash button It will unlock if I use the key in the door. I've got an appoin. at the stealers but I thought I'd check it out here first. Has anybody else dealt with this Could this be a software issue ie needs a reflash? Thanks |
02-23-2007, 11:25 AM | #2 |
Rep 12,276
Most likely a mechanical problem. I think the door locks are still operated by vacuum. Have you called the dealer?
I think it is bad luck to be superstitious |
02-23-2007, 12:32 PM | #3 |
Got Seoul?
116
Rep 2,862
Drives: 2012 535i MSport
Had the same problem and they had to replace the actuator that locks and unlocks the door. They had to order the part and was a quick fix. Take it to the dealer and they will fix it! I posted the thread so you can do a search.
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
10-09-2007, 09:14 AM | #4 |
26
Rep 526
325i Sparkling Graphite/Navigation/Steptronic/HeatedSeats/ DRL Angel Eyes/Metal Pedals/Tail Pipe Tips/Rear BMW Spoiler/BMWAlarm/LoJack/BlackLineTailLights/Hardwired BeltronicsProfessionalRX65RadarDetector/Rear FogLights/Debadged/LUX 5.0/ACS Roof Spoiler
10-09-2007, 12:09 PM | #5 |
Rep 799
You dont have to dig up *every* door locking/unlocking thread to post your thread in it. The point of the search feature is so that:
1) You don't have to start your own thread. 2) You don't unnecessarily annoy everyone by discussing previously discussed/resolved issues. You managed to screw both those up. |
10-09-2007, 11:37 PM | #6 |
26
Rep 526
I did perform a search with multiple words as others who posted their own threads.
If you don't like the way I brought this issue up now AND you do not have or have not had this problem with your doors, simply read a thread you are interested in. As simple as that.
10-10-2007, 01:45 AM | #7 |
Rep 18
door problem
try replacing fuse 56 and 57. its a 15 amps fuse. got one spare in the fuse box under inside your glove compartment. your unlocking actuator is going to be a goner and probably caused the fuse to blow.
10-10-2007, 04:22 AM | #8 |
Rep 178
10-10-2007, 06:12 AM | #9 | |
Montego Blue FTW
56
Rep 1,110
