hood not staying latched tightly-335d
02-03-2011, 10:41 PM | #1 |
Rep 149
Heads up - twice now I've had to pull off the highway because I've noticed the hood not staying latched down. Don't have reason to open it much, so the other week pulled off the highway b/c it looked like it was moving. It somehow had come open a bit and I pressed hard and it latched. Then just the other day was looking at the car in the driveway and the driver's side looked a bit higher than the passenger side. Gave it a little tug and sure enough it was loose again. Not staying latched completely in the front. The U brackets on the hood underside seem awfully loose also. Off to the dealer tomorrow..... Weird!!
2005 Mercedes SL55 (sold) 2006 Range Rover HSE (sold)
2006 Porsche 911 C4S Cab 2010 BMW X5 Diesel (sold) 2010 335D (sold) 2010 Range Rover HSE (sold) 2012 Q5 TDI (sold) 2014 Q5 TDI 2016 Audi A6 |
02-04-2011, 04:43 AM | #4 |
Rep 2,383
The "D" rings on your hood should not be loose at all.
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
02-04-2011, 07:54 AM | #5 |
Rep 2
Same thing is happening to my car. I have a dealership appointment next week to fix it. It seems to be related to the spring on the latch itself in my car. It is super slow and will not snap back into place. In the mean time if you push down a bit over the affected D ring, it will close.
02-04-2011, 08:17 AM | #6 |
Rep 5,018
Drives: VALNCYA
Check the bumper stops on both corners near the head lamps one side may be to high or to low.
02-04-2011, 11:01 AM | #7 |
Rep 286
Same thing happened to me as well...
Took like 15 minutes at the dealer. They said the latch wasn't aligned. I guess some german was having a bad day. Works perfectly now! |
02-04-2011, 11:07 AM | #8 |
Rep 149
At dealer now-seems the latch that the D ring goes in to was sticking open. Lubed latch and seems okay for now.
02-04-2011, 09:58 PM | #10 |
Rep 149
Well, that was at the dealer. Had the oil changed, prog. update, etc. Hood was closed when I left the dealer. Ran it on some errands and when I went to get in at the last stop, I noticed the driver's side of the hood had popped open again So, the fix lasted all of 1 hour. Guess I'll have to keep an eye on it and hope it doesn't fly open on the highway....
02-04-2011, 09:59 PM | #11 |
Very Important
20
Rep 450
Drives: 335xi (e92)
Garage List 2008 BMW 335xi (e92) [9.00]
2008 Pontiac G8 GT [4.00] 2002 Pontiac Grand ... [0.00] 2001 Cadillac, Eldo ... [0.00] |
02-04-2011, 10:11 PM | #12 |
Rep 149
Guess I'll compare the right side bumper, not having a problem w/ that side, to the left and see if there is a difference. Also, the srvc mgr today took the D ring stop off the side that was popping open and messed w/ the position of the that... Just don't want to start messing w/ too much at once and really throw it out of wack.
