Dam, Is this whats whats wrong with it??
02-04-2011, 04:33 PM | #1 |
Rep 774
Car starts shaking, vibrations when i get about 75 miles and above the higher i go the worse it gets, when i let of the throttle still same thing. Could my wheel weights be of or something?
02-04-2011, 04:44 PM | #2 |
bimmer freak
98
Rep 579
very well could be, thats pretty much the first/easiest place to start. go to a wheel shop and they can rebalance
02-04-2011, 05:56 PM | #5 |
Rep 2,284
Bad camber wear will cause tramlining on uneven roads, but won't vibrate. Vibration only occurs when you have bad toe, or if you have aftermarket wheel with no hubcentric rings installed.
Do you have aftermarket wheels? Did you hit a pothole, curb? If so, your tires/rim could be warped. |
02-04-2011, 11:47 PM | #6 |
Rep 95
Vibration can also occur if you have loose or worn wheel bearings, or a driveshaft out of balance, or worn or un-lubed u-joints, or any number of bent suspension parts. Go easy on the absolutes man. The good advice is to start with the wheel balancing and go from there.
E90 AW 330i Sport/Premium/Terra
02-05-2011, 01:38 AM | #7 |
German Spitz
10
Rep 219
Bent rim, worn bushings, strut mount bushings...
*Vishnu Exhaust/JB2 Tune
*BMW Performance Suspension/H&R Sport Springs/Eibach Spacers/19" Black M6 Rims *GP Thunder 8500k Angel Eyes/Corners/CF Emblems *Lexen LED Plate Lights/Black AutoTecknic Grille |
02-05-2011, 11:55 AM | #8 |
Rep 587
Drives: 2020 M2C
It could be control arm bushings. My 330ci had these same symptoms and that is what it was. What year is the car and how many miles on it? I think this occured on my 330 around 90k miles
02-05-2011, 12:02 PM | #9 |
Rep 6,604
Drives: e92 335i
could be any of the above things
