E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > reset model 320i - e90 0il serveice pls
Reply
      02-12-2011, 04:29 AM   #1
leeking
Drives: not now
Unhappy reset model 320i - e90 0il serveice pls
anyone help me an video hows to reset oil service for my bim , model 320i-e90 , thanks in advance
      02-12-2011, 04:40 AM   #2
infbp22
Drives: E30
You don't need a video, It's easy.
First of all, if it's under warranty you shouldn't do it, because the number of resets are logged in the control module data; take it to the dealer.
If you have navigation/on board monitor STEP 2 does not apply/matter
1) Start vehicle and leave running in Park
2) Press the BC stalk switch button until there is no data displayed in the center of the instrument cluster.
3) Press and hold the Trip meter reset (left) on Instrument cluster until the "service" symbol is displayed, followed by the needed service item.
4) Use the BC toggle switch to select a service or simply select the first service displayed (in your case oil service, genie bottle)
5) Press and hold the BC button again until it resets.
      02-12-2011, 07:46 AM   #3
Chriztofor
Chriztofor's Avatar
Drives: '06 325i and '13 X5
Here is the video (not sure if it applies to your 320i) http://www.e90post.com/forums/showth...t=series+reset
However, I agree with infbp22, if it is under warranty I wouldn't touch the car.
Reply
e90post
