Do You Have The OEM Alarm Installed In Your e90?
03-04-2011, 05:16 AM | #1 |
Rep 167
Drives: BMW 330d SE Saloon
Just discovered that I don't have an alarm in my car, this is my first BMW, and I assumed with a 330d, I'd already have an alarm!
Hmm. [s]Do most people fall for this trick? Is it expensive to retrofit? I suppose that's what you get for buying 2nd Hand! At the moment, not having folding rear seats and alarm have annoyed me so far...[/s] Whoo hooo! Alarm is standard, but in america its not (apparently!) Last edited by sattapaal; 03-04-2011 at 10:38 AM.. |
03-04-2011, 05:34 AM | #2 |
Rep 4,302
Drives: M135i
I thought an alarm was standard fit?
03-04-2011, 05:35 AM | #3 |
Rep 824
Drives: BMW 530e G30
yeh surely an alarm is deffo standard fit!!
BMW 530e G30
03-04-2011, 05:43 AM | #4 |
Rep 167
Apparently, to set it off, you hold down your Boot button for 5 seconds on your key and that should activate the panic alarm?
Also, if you try to open your boot with the key, it should sound the alarm.... Mine does nothing? |
03-04-2011, 05:44 AM | #5 |
Rep 824
yeh i heard that about the boot realease button and tried it but it doesnt work for me either....
BMW 530e G30
03-04-2011, 05:47 AM | #6 |
Rep 4,302
Drives: M135i
I take the removable key bit out when I go surfing (and stick it in an Aquapac)- The remaining remote bit goes in the car - when I unlock it (using the keyhole), the alarm sounds until I switch it off with the remote fob - could try that?
03-04-2011, 05:56 AM | #7 |
Rep 167
Thanks 335d, I'll try it when I get home....but searching the forum, no chirp, no alarm (american users).
Also, someone in the office has said that most used car dealers disable/disconnect the alarms? |
03-04-2011, 06:00 AM | #8 |
Rep 4,302
Drives: M135i
I ONLY hear mine when I go surfing - it's never gone off apart from then.
The Landy alarm goes off all the time when we accidentally arm it when the doors are still open - doh! |
03-04-2011, 06:36 AM | #9 |
Rep 5,950
Drives: M3 Comp Pack / QQ+2 Tekna
Garage List 2008 350Z GT Roadster [2.00]
2004 Honda S2000 [0.00] 2005 Nissan 350Z GT ... [0.00] 2006 E92 BMW 335i SE [9.00] 2003 Maserati 4200 [6.00] 2006 E90 330d M Sport [0.00] |
You'll definately have an alarm, and probably an immobiliser.
Chuck a brick through the windscreen - that'll test it .
Current -: MW E92 M3 Competition Pack / Qashqai+2 Tekna 1.6dci
Gone -: 370Z GT Roadster; BMW X3 3.0d xdrive M Sport; E46 330i M Sport Coupe; Mazda RX8 231; Nissan 350Z GT Roadster; BMW E90 330d M Sport; BMW E92 335i SE; Maserati 4200; Nissan 350Z; Honda S2000; Astra Coupe Turbo; Ford Probe |
03-04-2011, 07:12 AM | #11 |
Rep 564
Drives: e90 320D ED
lock car normally (indi's flash) take removable key out, and manually open the drivers door. the alarm will sound.
330D standard alarm is thatcham cat1.
Its all about the mpg!
03-04-2011, 07:15 AM | #12 |
Rep 8,111
Do you have the clown's nose on the mirror? Unless it's a dodgy import then it will definately have an "anti-theft device" as the law requires it in the UK.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
03-04-2011, 07:31 AM | #14 |
Rep 8,111
By law yes but I'm sure BMW never made such a configuration. Is the ultrasonic sensor box on the roof lining?
Ian
03-04-2011, 08:52 AM | #15 |
Rep 167
03-04-2011, 09:01 AM | #16 |
Rep 2,472
I never thought about doing that. I always just stick my key up under the bumper. Need to try this as I've got an aquapac for use with hire cars.
03-04-2011, 09:32 AM | #17 |
Squadron Leader (Ret'd)
25
Rep 627
You certainly have an alarm - even a base spec 316d ES has an alarm!
Look at the handbook and it will describe how to deactivate it for use on a ferry etc. |
03-04-2011, 10:37 AM | #18 |
Rep 167
Cool.
I feel stupid now. We have an alarm, its like a high pitched recurring beep. Wife used the simple method....use the damn key on the drivers side when the alarm is on. (I thought I did this, but it was dark when I tried!) Wonder why the boot key thing didnt work, or the rape alarm...? |
03-04-2011, 11:23 AM | #19 |
Rep 3,815
European cars dont have the alarm chirp anymore due to some EU legistlation in states you can have it so hence the no chirp no alarm comments on US side of things.
Thats one thing though I have about LCI no key hole in boot. Easiest test is lock car with windows down wait 5 minutes and reach fully inside should set it off. Or open it with the key in the door if its a LCI.
F30 335i M Sport - now departed
