Bosch Platinum +4 VS. NGK Platinum
03-16-2011, 01:19 PM | #1 |
Rep 208
So I wanted to get people's input on Bosch Platinum +4 and NGK Platinum
Which one you would recommend over the other (not other models)
◆ 325i Sports Package ◆ 20%/5%/20% Tints ◆ 19" M6 Miro Reps ◆ H&R Sport Springs ◆ Daeos (Vista) Harness ◆ Cold-Air Intake
►In Progress: CDV Delete, Clutch Pedal Stop, CF Interior Trim, LED Blacklines, Angel Eyes ►Future: Short Shift Kit, Front Amber Delete, Body Upgrades |
03-16-2011, 01:27 PM | #3 |
Rep 204
I doubt you'll notice a difference. They're both OEM. I use Bosch.. no complaints. But I agree that most ppl here seem to prefer NGK for some reason.
03-16-2011, 02:21 PM | #4 |
Rep 208
Yeah thats what I'm thinking... NGK.. I heard Bosch has some problem in mid-range firing... any difference between the 4 prongs vs 1 arc prong??
06-12-2014, 08:38 PM | #6 |
Rep 488
Drives: 2008 335xi E90
Max Power is all about maximizing load and timing without misfiring, no? So unless you can increase load or timing using the NGK plug over that of the OEM Bosch plug, then why change plugs? Is there any real data out there?
06-12-2014, 09:49 PM | #7 |
Rep 777
FWIW, iridium is the better choice vs. platinum
328i Sports Pkg, Michelin PSS on Staggered 18" OZ Ultraleggeras
. BMS Powerbox. Cyba scoops + Rev motoring intake hose + charcoal delete. Wavetrac LSD . M3: subframe bushings + sways + control arms (fr & rr). Meyle rear toe arms. M3 diff fr bushings . BMW Perf: v2 springs + v1 dampers. Valeo SMFW+clutch. 034 MotorSport engine mounts . Short Shifter + Turner PU bearing + ZHP M weighted shift knob. CDV delete |
06-13-2014, 06:03 PM | #10 |
Rep 108
Drives: 2006 330i
just replaced with oem (NGK)
06-14-2014, 07:45 AM | #12 |
Rep 95
06-14-2014, 10:24 AM | #13 |
Rep 1,834
Drives: '05 E90 330i Manual
Have Bosch Iridium - no problems. They replaced the original NGK Iridium plugs and there were no problems then and still going fine.
