BIMMERPOST Universal Forums Off-Topic Discussions Board Video + PC Gaming / Computing
      03-23-2011, 11:02 AM   #1
Slops
Slops's Avatar
South Africa
190
Drives: 2005 C55 AMG
Upgrading PC
I bought a HP Touchsmart 600-1350 a couple months ago, and since my ps3 died i wanted to play cod black ops on this bitch.
Problem... CPU seems a bit slow and the graphics card is pretty much non-existent.
These are the current specs for it...
http://h20000.www2.hp.com/bizsupport...odTypeId=12454
Here's the specs on the PC's motherboard and upgrades to it...
http://h20000.www2.hp.com/bizsupport...riesId=4269984
What do you think would be the best upgrades i could do here to make me kick ass online with this bad boy...
      03-23-2011, 11:08 AM   #2
Freakazoid
Freakazoid's Avatar
188
Drives: Saturn Redline
go i7 with that motherboard, find a cheap/reasonable used graphics card on ebay (look to spend about a $100, that'll be enough), and upgrade the ram....and you'd be set
      03-23-2011, 11:12 AM   #3
Slops
Slops's Avatar
South Africa
190
I have the Intel(R) Core(TM) i3 CPU M 370 @ 2.40GHz in it right now, and the closest comparison is the "Intel Core i7 620M Dual Core (A)" ... but would the "Intel Core i7 820QM Quad Core (C)" still work with everything else I have onboard like the integrated graphics etc?
I'm planning to use the MXM expansion slot with a graphics card but they are kinda hard to find right now
      03-23-2011, 11:20 AM   #4
Slops
Slops's Avatar
South Africa
190
Do you think this graphics card will fit my pc in the MXM slot?
http://cgi.ebay.com/Nvidia-Quadro-FX...item2a0e9d36ee
      03-23-2011, 11:28 AM   #5
Freakazoid
Freakazoid's Avatar
188
Yep, you wouldn't have any problems there (unless something has drastically changed with the mobile architecture). Upgrading the motherboard wouldn't necessarily be a bad thing...but I'm not sure you'd get the benefits you'd want outta it.
And depending on what you use the machine for, might want to think about a SSD disk too. Get a cheap low space one.
For your MXM question, can you check what version you have? (should be in your bios), this will be your more reliant factor here.
      03-23-2011, 12:19 PM   #6
Slops
Slops's Avatar
South Africa
190
hmm... i can't seem to find a version of the mxm slot in my bios - it says its a MXM 3.0 slot though in the specs.
      03-24-2011, 03:41 PM   #7
Slops
Slops's Avatar
South Africa
190
Thanks for your help Freakazoid!
      03-24-2011, 03:44 PM   #8
Freakazoid
Freakazoid's Avatar
188
with a 3.0 I'd probably get cheaper, I can try to point you in the direction of some ebay used deals if you want.
      03-24-2011, 03:50 PM   #9
Slops
Slops's Avatar
South Africa
190
Thats ok, i picked this guy up just to see if it'll work.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=230570911272
My guess is that it'll supercharge the whole system since the graphics bogs the cpu down so much. I tried to play COD online and its actually not too bad, but it isn't as smooth as it should be. Currently it only has 64MB dedicated to graphics so the 512 should help out a lot. If not, then i'll upgrade to the i7 dual core and another 4Gig memmory stick.
      03-24-2011, 04:17 PM   #10
Freakazoid
Freakazoid's Avatar
188
ya good idea, start with the graphics card. This should get you to a tolerable level. RAM would be the next jump. the i7 would be expensive, but would be beneficial. (and you could sell the old one)
      03-28-2011, 03:31 AM   #11
.user328xi
Drives: 07 328xi Black 4D
I highly doubt you'll find a i7 processor for 100$
      03-28-2011, 04:54 PM   #12
Slops
Slops's Avatar
South Africa
190
I think the i7 is around 600 bux or so....
Also after opening it up I saw that there is a huge difference between 3.0 mxm and mxm-I .... So I wasted some money figuring this out by buying that mxm-I off of eBay! Now I have a 3.0 coming which is what the hp firebird uses.
      03-28-2011, 06:10 PM   #13
Freakazoid
Freakazoid's Avatar
188
not saying you would by any means, I'm simply giving an alternative. the $100 figure was referring to the video card.
      03-28-2011, 06:11 PM   #14
Freakazoid
Freakazoid's Avatar
188
ahh yea, sorry mate, after you said you bought it I only quickly opened it up and didn't pay attention to which mxm it was. Good call that you corrected your mistake though
