2010 2011 BMW 5 Series Forum F10 BMW 5-Series Gran Turismo GT (F07) Forums General 5-Series GT (Gran Turismo) (F07) Forum BMW 535 GT Engine Noise
      04-01-2011, 12:43 AM   #1
goodiesmok
Drives: BMW 535 GT
Smile BMW 535 GT Engine Noise
Good day,
I have recently bought myself a BMW 535GT and its was magnificent!
There's a minor problem though, is that every morning when i start the car, there's an unusual engine noise (sort of like steel rubbing sound) that will last for 10-15 seconds. Then it goes back to normal behavior, smooth and silent.
Please help.
      04-02-2011, 10:32 PM   #2
car_fan
car_fan's Avatar
382
Drives: 2020 F97 X3M
2020 BMW X3M  [0.00]
  [0.00]
Originally Posted by goodiesmok View Post
Good day,
Please help.
Is it kind of like a "Screech" sound? I have heard it before when starting in cold climate - not always however. It almost sounds similar to a conventional manual key type ignition when the key is held in the start postion, after the engine has turned over.
These cars can be tempermental. If your car does it all the time, take it to your dealer so that you can show them by duplicating the issue/sound. Otherwise they probably will subject you to hours of reprogramming, because I doubt this will trigger any error codes if it happens on an intermittent basis.
just my two cents
2011 MINI CooperS BRGII/Lounge Green/Sport/Prem/Connect/Black Xenon/Black Conical Spokes/ACS springs/ACS exhaust/Alta Shorty/Yokohama Advan Sport A/S
2012 M3 AW/FR NDH2/2MK/ZPP/ZCP/ZCW/752/6NR/OEM CF splitters/OEM CF Mirror caps (retired)
2012 X3 35i Titanium Silver/Black ZAP/ZPP/TECH/APPS/Breyton GTS (retired)
2018 X3 M40i BSM/Oyster/ZPP/ZPX/HK/S6CPA/718M(retired)
      04-21-2011, 12:20 AM   #3
BCKator
Drives: 2010 535GT
I noticed a strange sound as well on the 1st 535gt we test drove. But after hearing the same on every one, I assume that it is normal. All 2010s BTW. Ours still makes the strange sound at startup. No other issues.
      05-19-2011, 08:35 AM   #4
yclinn
Taiwan
Drives: BMW F07 Neptune Blue
My 535GT happened to make noises from the engine room, especially when idle, I don't know where did it come from.
http://youtu.be/DnBW6VNCFq4
      06-29-2011, 03:36 PM   #5
magnumforc
Drives: 328i Arctic Metallic, Beige,
Sounds like a loose belt or maybe a tensioner with a bit too much clearance on the bearing to me. When they heat up, the sound disappears and it's likely you'll have no trouble. We used to check with belt spray on the belt to see if the belt was slipping a bit, but not needed with todays serpentine belts. As long as it quits in 10-15 seconds, I'd say it's no need to be concerned.
5post
