      04-18-2011, 02:47 AM   #1
abisson
Canada FTW.
abisson's Avatar
Drives: 2016 VW R - Stg 2
Do spacers affect your car's drive?
Just a general question.
When you put spacers on your car, lets say 10.5mm, does it affect handling or anything like that?
      04-18-2011, 04:11 AM   #2
Artmasterx
Artmasterx's Avatar
48
Drives: 2007 BMW 335i
2006 Volvo V70R  [10.00]
2007 BMW 335i  [10.00]
It probably depends on why you are using them.
If you are using them to push your wheels out 10mm, then it will affect handling because you are widening the track by 20mm, but it may not be enough to notice or worry about. It could also change your suspension geometry slightly, maybe some experts can weigh in on it.
If you are doing it to compensate for an aftermarket wheel that doesn't have the proper offset to fit the car, then maybe not. Again it depends on if the track width will change.
In general, I would suspect minimal handling changes, but I am not an expert.
Regardless, make sure you use the appropriate nuts/bolts that account for the spacers, the last thing you want is to sheer off bolts because they were too short and then drop one of the corners to the ground... that would a bad day, and really dangerous.
Current: 2007 335i sedan
Alpine White | Sports | Premium | Cold | Comfort Access
FORMERLY: 128i coupe
Alpine White | Sports Package | Black Leather
      04-18-2011, 09:47 AM   #3
RioGrandeValley
RioGrandeValley's Avatar
59
Drives: E92/E90 Depends on Mood
Agree with above reply. I've seen 911s on track running 40mm but with that extreme it was significantly improving handling. As for our cars 20mm wider track I'd have to say not really. Only concerns I'd have are: tires rubbing if aftermarket wider wheels and tires,
Proper size bolts and finally getting an alignment to avoid uneven wear. Ive been running 10mm in front and 15mm on rear with 10" wheels. Only problem I have is rubbing but only thru bumpy roads. Nothing my volume knob can't drown out.
Tomato
      12-07-2014, 09:00 AM   #4
sanage
Drives: suzuki
Hmmm...nice...thanks for sharing.
Are you worried about 156-215.75 exam prep and Testking certification practice mica Check out our latest resources for www.quincy.edu dumps and University of Kansas
      12-07-2014, 10:36 AM   #5
D_o_S
LCI'd
281
Drives: 335i LCI
I have only ever felt the negatives of spacers, TBH...
Had 15mm spacers installed on a GTR (all round) and the car felt unwanting to turn vs. without spacers...
      12-07-2014, 11:14 AM   #6
ptack
ptack's Avatar
Drives: 135i
2008 135i  [6.50]
You'd have to be an experienced driver on a track to really notice a difference with 10.5mm spacers. There are scores of other things (like having passengers) that would have greater impact on the handling.
135i, SGM, Coral, Sport Package, Auto, Premium Hifi, USB/ipod, Apex EC-7s, PPK Stage II
      12-07-2014, 11:44 AM   #7
IEDEI
Drives: L'Orange
2011 BMW 1M  [8.40]
YES.
spacers add lots of unnecessary unsprung weight...most of the time for just cosmetic reasons. in case you don't know about unsprung weight-----1lb of unsprung weight is equivelant to adding 7 to 9 lbs of sprung weight.
so those spacers that weigh 2 lbs each (may weigh more than that, in reality) and adding about 15 lbs per corner. 60 lbs total to the actual 'feel' of the car. But worse than that, the fact is that adding unsprung weight makes the car's handling duller, braking slower, and adds stress to the hub componenets.
avoid spacers, IMO.
