E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Engine reduce speed
Reply
      04-20-2011, 09:56 PM   #1
charles.soori
Drives: 2016 F85 x5m
Engine reduce speed
Hi, So here is my problem i was driving today and all of a sudden my engine reduced power light comes on and i loose some power. But i still have about 15min of drive home so i try to rush home and 5 min into it i got no power i could only go 30km so after about 40 min i get home and i use the bt to check for code and i get this. I have no idea what needs to be changed?
Any help would be great
e90 2008 3281
2A3F:
Error will not cause a warning light
Error is currently present
Test conditions have not been completed
Signal or value below threshold
Freeze Frame Information
Event 1Odometer 33672kms 20922miles
voltage Kl. 87 14.52 V
status motor control 2.00 0-n
deviation Lambda probe from Lambda model value monitoring 0.00 -
2A77:
Error will cause a warning light
      04-20-2011, 10:17 PM   #2
MPI_Jack
Drives: '15 X1 35i , '02 530i(turbo)
Looks like an O2 sensor problem. Doesn't specify which bank it is though. If your wiring checked out, looks like you'll need an O2 sensor. But with out the full details, I wouldn't be able to give you a straight answer.
'15 E84 X1 35i M Sport
MPI DME Flash - K&N drop in - MPI Chargepipe - Oil T-stat valve - ETS 5" I/C - N54tuning 3.5" downpipe - catless mid section - Dinan 135i rear exhaust - Apex ARC8 18x9/10(255/295 tires) - H&R Sports - Bilstein B6's - F3x M Performance brakes
'02 E39 530i 624whp/558ft-lbs @23psi
      04-20-2011, 10:32 PM   #3
charles.soori
would it be the probe or the monitor sensor? I never new because of an o2 sensor the car would go into limp mode.
      04-20-2011, 10:41 PM   #4
MPI_Jack
It honestly shouldn't. I have rarely seen an N52 go into limp mode over an O2 sensor. The sensor is a probe/monitor. Does it specify which bank it happened on? What tool are you using to diagnose?
      04-20-2011, 10:50 PM   #5
charles.soori
I'm using the bavarian technic pro...i think it said bank 1..i'm going to look for loose connection tomorrow and see..but before i used the bt tool i used a reg obdII reader and that one said P1056 vvt supply voltage control and P105b Internal control module vvt error voltage too low, i cleared them and the error code didn't come back. I'm only left with 2A3F and 2A77
      04-20-2011, 10:58 PM   #6
MPI_Jack
If everything is fine(e.g. no corrosion on the pins of the connector, chaffed or cut wiring) I would replace the O2 sensor. If you had the means of checking the wiring from the 02 sensor connector to the DME for reistance and shorts to power or ground, I would do so for good measure. But I highly from experience believe you need an O2 sensor. Seen this many times.
Also see if you can get a replacement Bosch sensor from a local auto parts store. Its much cheaper and the SAME exact sensor without the BMW stamp on the connector.
Let me know the outcome. Best of luck to you. I hope this has helped.
      04-20-2011, 11:02 PM   #7
charles.soori
http://www.realoem.com/bmw/showparts...10&hg=18&fg=10
Which one would be bad out of 4?
      04-20-2011, 11:06 PM   #8
MPI_Jack
I would need to know if it's bank1 pre or post O2 sensor. More than likely it's #1.
      04-20-2011, 11:11 PM   #9
charles.soori
Thanks for the quick reply i'll check for loose connection and keep you posed
      04-21-2011, 12:49 PM   #10
charles.soori
found the problem...the pulg that connects on the battery to power the computer was loose.
      04-21-2011, 06:49 PM   #11
MPI_Jack
Good job, no codes came back?
      04-22-2011, 01:07 AM   #12
charles.soori
no code came back everything is fine now
      08-24-2012, 11:21 PM   #13
haroon
Drives: 2009 e92 m3
dam it i have the same issue try everything i can think of
check all fuses change the batt
check for a short still nothing plz any help would be great
2009 bmw 328xi
same codes
      10-15-2012, 12:57 PM   #14
mike281
Drives: 2007 335i coupe
Had the same problem. One of the fuses of the fuse block in the luggage compartment on top of the battery was blown. It's the fuse for the wire that goes to the 40A fuse in the ECM compartment. Had to replace the fuse block on top of the battery.
      10-15-2012, 04:48 PM   #15
mike281
      10-11-2013, 12:32 PM   #16
jfkipp
Drives: 07 328XI E90
Limp mode 2A77 2A3F Valvetronic actuator error?
Hi, Just to clarify are you saying you replaced the entire red battery distribution box that slides over the actual battery in the trunk? I have the same issue but it seems more intermittent and if I reset the ECU the car seems to start and run fine though I'm afraid I'll be stranded back in Limp mode. Also I thought the Valvetronic actuators were only in the M3's Not the 328xi...
      06-19-2016, 02:27 PM   #17
5tony
Drives: '21 M5/'15 X5 35i/'88 M3
Can any of you tell me what the eventual fix was? Having similar issues.
Reply
e90post
