Homelink Retrofit HELP!!!
04-23-2011, 07:57 PM | #1 |
Rep 2,095
Drives: 2019 Toyota Tacoma TRD OR 4x4
Hi,
First of all, I know this is in the wrong section but I need some help now and thought that posting in this section should get more views. I am installing the mirror with compass, homelink and autodimming on my 06 325i that did not come with it. I am using the retrofit cable(pn: 61120434330). What I need to know is what pins cables A2-A5 go into on the connector that plugs into the mirror(A1). I can't find it on any of the DIYs and the PDF instructions from BMW don't say either.
E90 325i|Sparkling Graphite Metallic|Steptronic|Black Leatherette/Dark Burl Interior|OEM Alarm|35%Front/5%Rear Tint|RD LED License Plate Lights|Rear Fogs Activated|Debadged|Smoked Sidemarkers|Blacklines|Depo P90v2|Matte Black Grille|BMS PBX|AFE Drop In|Charcoal Filter Delete|Air Scoops| RM Silicone Intake Hose| Magnaflow 14815| 19" Avant Garde M310|Continental DWS|M3 Lip Spoiler
04-23-2011, 09:16 PM | #2 |
Rep 2,095
Nevermind, I figured out how to do it. The circuit diagram at the end of the PDF shows what pins the cables go in.
Now the mirror won't work though. The wires are in the right pins and I checked the mirror on my wife's car and it works. Anyone have any ideas why its not working on my car?
04-24-2011, 10:25 AM | #4 | |
Rep 40
04-24-2011, 12:58 PM | #5 |
Rep 2,095
I checked and the all the pin connections are right. I checked fuse 28, which is for homelink, and it is working. IDK what else could be the problem.
04-25-2011, 05:52 AM | #6 | |
Rep 40
If it doesn't it's a cable issue; since you know the mirror works with your wife's cable in her car. I really doubt it's the FZD - my guess is a wire is loose in the cable assembly - have you checked continuity of each wire to be sure one did separate from the pin? BTW - when you say working in your wife's car, I assume you mean the Homelink operates the garage; based on your looking for the Homelink fuse. |
04-25-2011, 06:48 AM | #7 |
708
Rep 3,268
Drives: 2010 128i
Will be following this thread to see what the problem ends up being, as I intend to do this retrofit myself.
Anyone know if High Beam Assist can be retroftitted at the same time? My understanding is that it uses the same Homelink mirror with the addition of a small camera - not sure if it's plug-an-play, though. Sorry for the slight threadjack.
____________________________ |
04-25-2011, 09:29 AM | #8 | |
Rep 40
Best part - Under $150 for all the parts I needed and worth every penny. BMW should make it a standard item (at least Homelink and autodim) on 30K+ cars, IMHO. If you buy the mirror off ebay I'd email the seller to see if they have the wire harness as well and get them to throw it in; or if you go the salvage route grab it when you grab the mirror. PM if you have any questions. |
03-09-2012, 05:37 PM | #9 |
Rep 2,979
Drives: 07 SBM E92 335i 6MT
What ever happened with this?
In the process of restoring an 07 335i
03-10-2012, 04:45 AM | #11 |
Rep 134
Found it here if anyone needs: http://www.e90post.com/forums/showth...light=homelink
03-10-2012, 04:45 AM | #12 |
Rep 2,979
There is. But not one that actually walks you through every step like you're a dummy...which is what I needed. Or at least I would have gotten it done much faster if there was one that walked you through every step like a child.
If you need help, let me know...
03-10-2012, 04:48 AM | #13 |
Rep 134
Thanks, ye thats what I need cuz im not really an expert in this, only thing I installed myself is angel eye bulb. I will see if it is not so complicated I might just try installing it myself.
03-10-2012, 04:51 AM | #14 |
Rep 2,979
It's not complicated at all, believe me if it could be explained right. I'm a dummie when it comes to this stuff....so it took me an hour of looking at everything over and over to figure out where everything goes. And once you do see, you realize how easy it is. Trust me, don't pay someone to do this. It's only difficult physically, not technical at all.....
03-10-2012, 04:59 AM | #15 |
Rep 134
I will give it a try then, guess most important is to take ur time and if I get stuck there is always forum to ask.. Just one more question, does it matter if I have alarm or not? I have, does that make installation easier and does it mean that I already have wiring or it does not really matter? What is approx price of mirror with compass and home link?
03-10-2012, 06:29 AM | #16 |
Rep 2,979
I have no idea about the alarm...I don't have one so I really don't know. No one mentioned that in the DIY's that I can remember.
I paid $200 for mine. If you search autodim or homelink, I think there are a few for sale on here. I think you could get one for as low as $100-150. And people mentioned buying them on ebay for $80. Here's the dummie tips.. 1. All you need from the retrofit kit is the wiring. All the extra little pieces are just in case you break one of the pieces that are already there...or if you just want to replace them for the hell of it. The piece that is used on the mirror itself is hard not to break so you will probably have to use the new one in the kit. 2. You're just running the wires from the 20 pin middle/black connector in the upper/front console to the 10 pin connector in the mirror. I know this is something that should be common sense and easily figured out in the first place. But no DIY actually says this at the beginning. If I would have known that in the 1st place, I would have been able to do this MUCH faster. I spent an hour just staring at diagrams and trying to read through so much until I finally realized that. You have to cut the rubber piece off the retrofit wiring and then look at the diagram (best shown on the link below) and plug them in, then put everything back. 4. Make sure when you slide the gray 20 pin connector in the console back in..you use the arrow on it to slide it in the right way. I did it wrong the first time. Stupid I know...but just glancing at it, you CAN put it in wrong. 5. To get the console open, go in from the windshield side. I knew this from doing my LED interior kit. The clips are damn near impossible to do from the rear. 3. I cracked my windshield trying to put the homelink mirror on. So be VERY careful doing this. Hopefully your's won't be so damn difficult. http://www.bmw330i.info/projects/mirror.php
03-10-2012, 09:34 AM | #17 |
Rep 2,095
For those of you wondering if I was able to solve the issue...I never got it figured out but I didn't keep trying either. It was too annoying trying o figure it out with no luck, putting everything back together and trying again the next day.
03-10-2012, 09:50 AM | #18 | |
Rep 134
03-10-2012, 10:13 AM | #19 |
Rep 2,979
There is a DIY in the DIY section. And there's links inside the DIY's to click on that help.
