E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Cylinder 1 Misfire
Reply
      04-24-2011, 07:38 AM   #1
cstraface
cstraface's Avatar
Drives: 2007 335xi 6MT - SOLD
Cylinder 1 Misfire
Only get the misfire code with a tune installed - first it was the original JB (about 3 months ago before I pulled it b/c of the misfires) and as of yesterday, JB4. No CEL stock, although I have noticed the famed "hiccup/groan/cut-out" at WOT around 3,500-4,000 RPM.
I know, I know - most likely coil, plug or injector. I think I'm going to pull the JB4 and just take it in. Still have 10k left on original warranty.
But here are my 2 questions: why does the tune exacerbate the problem? One would think a bad coil or a bad plug is just that...bad and not working properly. A stock engine still needs to fire that #1 cylinder...right? I can possibly see an injector...do the tunes increase flow or pressure or something? Am I eligible for the injector recall? 4/07 manufacture date.
Question 2, would you guys leave the misfire code, pull the JB4 and head to the dealer? I'm worried if I clear the code, pull the JB and take it in I will get the old, "Technician could not replicate" bull.
2007 335xi 6MT || SOLD
      04-24-2011, 09:18 AM   #2
wren57
Roll Tide
wren57's Avatar
591
Drives: 335i
1) Because it increases the demands on the engine: ignition, fueling, etc
2) Remove JB4, clear codes, drive around until you get the CEL again.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306
      04-24-2011, 10:45 AM   #3
cstraface
cstraface's Avatar
That's the problem...I don't get the CEL driving around stock. Well...at least I haven't prior to...
Reply
e90post
