Car feels like it was pushed forward standing still
04-28-2011, 04:41 AM | #1 |
Rep 1,531
Every now and then when I am at a dead stop, it feels like someone tapped the back of the car. My foot is firmly on the brake. In fact twice I was at the gas station filling up with the car off with radio ready on and felt the same thing. Very strange. It has happened about 5 times in my first 3000 miles and after the car is driven at least 20 miles. Scares the crap out of me when it happens as I look in the rearview mirror and no one is behind me.
2021 M40i Phytonic Blue / Black Vernasca
2020 X5 xDrive 40i Tanzanite Blue / Coffee Vernasca 2011 328xi. Space Grey - Sold 188,925 great miles |
04-28-2011, 11:19 AM | #2 |
Rep 7,089
Drives: '06 AW 330xi
04-28-2011, 01:12 PM | #3 |
Rep 691
its the NIC, although it is strange that it react that way, but BMW consider thats normal, but I think its just poor engineering
04-28-2011, 01:17 PM | #4 |
Rep 691
here is the service bulletin:
SI B 24 06 06 Automatic Transmission October 2006 Technical Service This Service Information bulletin supersedes SI B24 06 06 dated August 2006. designates changes to this revision SUBJECT A Slight Bump is Felt Shortly after the Vehicle Comes to a Stop MODEL E85 3.0 and 3.0si with the GA6HP19Z transmission produced up to 07/2006 E90, E91 All with the GA6HP19Z transmission produced up to 09/2006 SITUATION A slight one-time bump is felt shortly after the vehicle comes to a stop. CAUSE This is due to the design concept of "NIC", or Neutral Idle Control. This gearbox feature uncouples the torque converter whenever the vehicle is stationary, gearbox oil temperature is between 20°C and 120°C, and the brakes are applied. By disconnecting the torque converter the load on the engine is reduced to a minimum. Please explain this feature and its operation to the customer. CORRECTION For the E85, revised EGS software is available with Progman 23.0 or higher. For the E90, E91 revised EGS software is expected in a future release of Progman. Until that time, on a customer complaint basis only, this feature can be deactivated as described in the procedure below. PROCEDURE E85 – On a customer complaint basis only, reprogram the EGS module with Progman 23.0 or higher. It is not possible to deactivate this feature using the retrofit option on the E85. E90, E91 - On a customer complaint basis only, perform the Retrofit - "Converter lockup clutch" using Progman 23.0 (Target Data status: E89x-06-09-520) or higher. Follow the "Retrofit" procedures as outlined in SI B09 05 01. |
