Washer Fluid Bottle?
05-02-2011, 11:04 AM | #1 |
Rep 126
Drives: 2006 325XI Wagon
How do I get to the bottle? I have a slow leak in it and i'm not sure if it is a loose hose, or a cracked hose. I cant see how I get to it to check it out. Maybe someone has the diagram of this area of the car they can post.
thanks in advance.
05-02-2011, 11:21 AM | #2 |
Rep 402
IIRC, the washer fluid bottle in on the passenger's side, in the wheel well. You need to remove the front passenger tire, and then remove the wheel liner. The fluid bottle is located in the rear of the wheel well.
05-02-2011, 11:23 AM | #3 |
Rep 126
Are they known for leaking? Is this common?
05-02-2011, 11:44 AM | #4 |
Rep 138
My car seems to drink washer fluid as well (once every 2 weeks it seems i have to fill it) so i would be interested in this too...
2020 Sunset Orange 330i xDrive|Sport|Convenience
OLD: 2007 SGM/Black 328xi|6MT|Sport|Premium|Xenon |
05-02-2011, 11:45 AM | #5 |
Rep 126
Mine will leak after driving, then seal up as it sits. Then after another ride, it starts leaking again.
05-02-2011, 05:55 PM | #7 |
Rep 155
05-02-2011, 06:11 PM | #8 |
Rep 677
05-02-2011, 07:55 PM | #9 |
Lucky13
212
Rep 1,762
I have the opposite problem in that I can't get fluid to come out. I already have had it into the dealer twice and they told me the screen was plugged and they fixed it. Two weeks later and its doing the same thing so it looks like trip number three.
05-02-2011, 08:20 PM | #10 |
Rep 126
So the car is out of warranty, so $200 trip to fix a leak is not an option. How do I get to the bottle? Fender trim, or from under the car? I am not going to pull off the fender to do it. I would rather deal without. What was BMW thinking on this shotty design? VW's have a better bottle design.
05-02-2011, 10:11 PM | #11 | |
Rep 177
My washer pump was the cause of the leak I was experiencing. The pump worked fine however it was leaking through the vent hole on the side of the pump. It seems to be a common problem.
