e93 top how to close manually
05-04-2011, 10:28 PM | #1 |
Rep 219
alright guys i need some major help my e93 335 got hit from the back and now the top wont come down i need a way to make it come down manually any help here, its like locked in place or something the body shop and mechanic shops cant figure out how to get the top down, is there like a spot were u can screw it out from being locked or something
sapphire black e93 335i |
05-04-2011, 10:35 PM | #2 |
Rep 2,554
that's not a very good body shop now is it?
05-05-2011, 02:00 AM | #5 |
Rep 219
to be honest it wasnt only 1 bodys hop it was a couple of them and then a couple of bmw techs
05-05-2011, 02:01 AM | #6 |
Rep 219
i think that was for the sunroof =( i read it to i didn't find anything about the top it self it only showed stuff about the sunroof whitch i dont understand why they would but that in the e93 manual
05-05-2011, 02:15 AM | #7 |
Rep 1,428
Drives: '23 i4 M50, '15 M3, '18 911
I owned an E93. One thing that was both scary and cool is how complex the roof is. It wouldn't take much body tweaking to make the roof inoperable. And I can't imagine how much it would cost to fix it once the car is damaged.
Why in the world would you want to open the top if the car is damaged? You might never be able to get it closed again. There are clearly belt-driven mechanisms in the roof. I don't see how you'd be able to 'force' it short of disassembling the entire roof. I wouldn't touch the roof until the body damage is dealt with. |
05-05-2011, 05:07 AM | #8 |
Rep 135
there are 32 sensors in the roof alone, something like 70 overall for the mechanism. Any manual intervention would damage the sensors. The roof + Sensors are near $3500 - $4000. Then there is no easy manual way of doing it, bmw engineers know the tricks so they should deal with it.
05-05-2011, 06:11 AM | #9 |
Rep 329
That was my first thought as well. Go to a body shop that is familiar with E93s.
A
2011 BMW 335is Convertible
2011 Toyota Sienna Ltd AWD 2010 Lexus HS250h 2010 Honda Civic LX |
05-05-2011, 06:42 AM | #10 | |
Philosopher-king
20
Rep 1,113
E91 6MT Alpine, Terra, Xenons, ZSP, ZCW, ZPP, PDC, CA, alarm, M shifter and M brake handle, Euro rear fog light switch, Euro aspheric mirrors, rear power outlets, Garmin nüvi custom cupholder mount, Lidatek, V-1 built-in remote display, tire pump, jack, floor mats.
05-05-2011, 11:23 PM | #11 |
Rep 746
hey
not sure how accurate this is since i dont own a e93 but ppl have had success by removing the plug form two modules that run the smarttop. Removing the plugs resets the top and some have had success with this method. THis link has a comfort access installation procedure but some have used it for gaining access to at least one of the modules for resetting purposes.
http://www.bimmerfest.com/forums/sho...story+smarttop if that doesnt work, then u might have a failed sensor which is also somewhat common but costs $500-$1000/sensor and labor from stealership. goodluck, hope this helps |
05-08-2011, 03:21 PM | #12 |
That tickles
11
Rep 457
There is no manual way to open/close the retractable hardtop. And FYI, the replacement cost of the entire roof (should the whole thing need to be replaced) is just under $17,000--and that's *before* labor!
10-29-2012, 10:27 AM | #14 | |
Rep 600
It would be difficult for anyone, regardless of how deep their pockets are, owning a high mileage E93 and spending $17,000+ to have the fancy top working again.
Jay (in San Antonio, TX)
2014 428i coupe, mineral gray metallic with black interior, black ash trim, luxury edition. |
10-30-2012, 11:12 PM | #15 |
Rep 97
To echo prior posts, why do want the top down given that you may not be able to get it back up?
If you are asking can I continue to operate the top without having it fixed that's a big stretch. I think you need to either have it fixed by a BMW dealer or accept the fact that your vert is now a coupe. PS: To address another prior post the top doesn't have any belts, it is all operated with hydraulics driven by electric motors. |
05-23-2013, 04:29 PM | #16 |
Rep 1,255
05-23-2013, 07:21 PM | #18 |
Rep 630
Drives: '09 335 E93 6MT
11-08-2016, 04:33 AM | #19 |
Rep 11
http://workshop-manuals.com/bmw/3_se...gency_opening/
Any ideas about the "special tool 54 0 163 together with special tool 13 5 250"? Do you have pictures of these tools? Or any other ideas to close the top without those? Thanks! |
11-08-2016, 12:43 PM | #20 | |
Rep 554
Drives: 2013 335is E93 6MT
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
11-08-2016, 01:48 PM | #21 |
Rep 666
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
