On-Board Diagnostic (OBD) test result - question on Pin 16
05-12-2011, 01:37 PM | #1 |
***** noob
1378
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
I had my state inspection done and on the report under the OBD test results, there’s a “Pin 16 Volts Check” on there. Is this the Voltage from the alternator? This test show 11.7
Is my voltage too low? I remember reading something on the voltage that it should be around 14. I checked last year’s test and it was at 14.4….or is this just some other test and no need to worry about???
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
05-12-2011, 08:59 PM | #2 |
***** noob
1378
Rep 10,479
no one knows?
2006 325xi (Sold)
05-12-2011, 10:23 PM | #4 |
***** noob
1378
Rep 10,479
so its the battery and not the alternator? if the test is under 11 than inspection fail?
if its just the bettery, then i can sleep tonight since my battery is due for change anyways
2006 325xi (Sold)
05-13-2011, 07:05 AM | #5 |
Rep 2,373
the voltage on that pin is read in this case obviously with just the key on and not with the car running-thus the low reading. While 11.7 volts is low with the key on it doesnt signify a charging issue...id charge the battery or if its older replace it.
05-13-2011, 07:18 AM | #6 |
***** noob
1378
Rep 10,479
learn new things everyday....thanks folks
2006 325xi (Sold)
