2010 2011 BMW 5 Series Forum F10 Another transmission rant |
05-13-2011, 04:57 AM | #1 |
Rep 3,016
OK, so we all know that the F10 transmission automatically selects park as soon as you open the door, but it would appear that the the car's warning system doesn't.
Last night I parked in my driveway and as usual I selected neutral to allow the car to come to a standstill in a slight hollow because, that way, it doesn't stress the transmission lock and I prefer not to keep the parking brake system pressurised overnight. The only thing I did differently from normal was to switch off before selecting park. The 'bong' immediately sounded and a warning message appeared on the screen telling me that it would not be possible to lock the car from the outside with the car in neutral So what did it think I was going to do - climb out of the window just so that I could leave it in neutral? Damn thing doesn't know it's arse from it's elbow |
05-13-2011, 08:08 AM | #2 |
Rep 519
Jon D.
Actually there should be nothing to worry about in using your parking brake. When I first rotated my tires I looked at this system and there is actually an electrical motor assembly on each rear wheel that physically push the pads to the rotor. That was one of my secondary concerns when I brought up the whole "putting the transmission in Neutral" thread as it related to having a breakdown. If the parking brake is on as well and lets just say that the Battery completely craps out, how do you release the parking brake? I guess you drag the car on the flatbed..............because unless I am missing something....the rear wheels won't budge. |
05-13-2011, 08:29 AM | #3 | |
Rep 1,684
I believe my f1 has a tool in the toolkit that is designed to release the parking brake under such circumstances. Unless it's for another purpose.
05-13-2011, 08:51 AM | #4 |
Rep 519
Since September, the tool is no longer included with the 5 series. Prior to that, one could physically unluck the transmission and the rear brakes........no longer. The transmission can now be unlocked by a series of moves on the shifter, but if power goes out............... we are all out of luck.
05-13-2011, 10:07 AM | #5 | |
Rep 3,016
In other threads I've frequently commented on the fallibility of the system in that, other than lifting the rear wheels off the ground, the car cannot be moved in the event of an electrical failure. Potentially very dangerous if you break down halfway round a blind bend or a similarly hazardous situation. Not quite so bad if you have an engine failure, but still have electrical power - you can select neutral by cranking the engine at the same time as operating the gear lever. |
05-13-2011, 10:18 AM | #6 | |
Rep 1,684
Wow, that sux. First the dipstick, then the spare tire, and now the parking brake tool. What's next?
Can you confirm if the old tool would still work even though they don't give it to you in the event of a power failure? Or, is the tool not going to work anyway? Quote:
05-13-2011, 10:40 AM | #7 | |
Rep 3,016
As to dipsticks, at least my 535d has one and I get pleasure every time I check the oil level - still exactly on the top notch after 7k miles. If there's any loss it's indiscernible and probably entirely due to what I wipe off when checking. |
05-13-2011, 11:25 AM | #8 | |
Rep 519
