seafoam
05-15-2011, 07:38 PM | #1 |
Rep 1,783
seafoam
I put seafoam in the vacuum pump yesterday. There was a lot of smoke coming out of the exhaust and was reving it past 4k rpm. The smoke went away so I thought it was fine but I didn't drive anymore for the day. So today I'm driving and all of a sudden the car starts losing power I stop then all of a sudden white smoke surrounds my car. So I rev the engine I for about 15 seconds. The smoke clears and I see a kid on a trycycle staring at me with his mouth open. So I go back home in limp mode restart the car and is running like new again.
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
05-15-2011, 07:38 PM | #2 |
Rep 8,693
Drives: 06 330i
seafoam is crap
05-15-2011, 07:42 PM | #3 |
Back in a BMW
205
Rep 5,208
Op, just wait till car is warmed up and do a 0-155 pull... it should blow out all the buildup
Ian
05-15-2011, 07:44 PM | #4 |
Rep 1,558
We tried seafood at our shop when it first came out on a Malibu and during the test drive it blew up, the stuff sucks, I can't believe they are still in business, this isn't the only case I've heard of either, a shop down the street had it happen a few months later as well on a Yukon.
Sport pack, JB3, Dci, factory oil cooler, 18" M3 reps, Michelin PSS, painted trim, black grills, smoked side markers, LED plate lights, H&R coils, Borla catback |
05-15-2011, 07:46 PM | #5 |
Rep 8,693
Drives: 06 330i
i bet if you hooked up my girl to your vac port she could blow more shit out of your motor than seafoam.
happy 6,000 posts to me! |
05-15-2011, 07:48 PM | #6 |
Rep 3,158
If you want something a bit more useful (but still dangerous):
water Yes, plain old water. Let small amounts of it get sucked up into the intake, enough to drop the engine RPMs a bit, no more. Do this for perhaps a pint's worth of water over a period of, say, 20 minutes. The water flashes into steam, and viola! Steam cleaning. The biggest danger of this scheme: hydrolock. Bad juju, that.
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
05-15-2011, 07:48 PM | #7 | |
Rep 8,693
Drives: 06 330i
do NOT listen to that guy. |
05-15-2011, 07:49 PM | #8 | |
Rep 1,325
Using seafood was your problem. |
05-15-2011, 07:50 PM | #9 | |
Rep 3,158
http://www.automotivehelper.com/topic201270.htm http://forums.sohc4.net/index.php?topic=25550.0 http://www.bobistheoilguy.com/forums...Number=1870233 http://www.berrysweb.com/steam_clean.htm
--Mark Twain |
05-15-2011, 07:53 PM | #10 | |
Rep 8,693
Drives: 06 330i
im sorry, i don't care who is recommending it, im not putting water in my engine. mikeistheoil guy suggests you should pour a gallon of distilled water and my dip spit in your motor to remove all carbon buildup. please dont confuse your self. water injection is a mix of water/alc. little different. |
05-15-2011, 07:57 PM | #11 |
Rep 3,158
Fair enough, if you don't like the dangers associated with it, then don't do it. But it works, and to claim it doesn't is....wrong. Against-the-facts style of wrong.
It's been in use and working since approximately the invention of the internal combustion engine.
--Mark Twain |
05-15-2011, 08:24 PM | #12 |
Rep 8,693
Drives: 06 330i
05-15-2011, 09:10 PM | #17 |
Rep 8,693
Drives: 06 330i
05-15-2011, 11:01 PM | #18 |
Rep 1,783
I believe only when you put it directly in the oil. Just realised that I left it in the engine for about 20 hours, hopefully nothing bad happend.
05-15-2011, 11:29 PM | #19 |
Rep 1,783
Lol that's what I thought
05-16-2011, 05:05 AM | #21 |
Rep 1,558
Yeah it came out in the 30's for outboard motors, and they probably haven't changed it since, its no wonder it does not work for todays advanced engines.
05-16-2011, 08:08 PM | #22 |
Rep 1,783
Update!
Drove the car to 105 mph today and no problems. Seems as if it revs smoother and the engine is a little quieter... gotta get that cold air intake.
