Light bulb light came on after installing pbx
05-17-2011, 10:40 AM | #1 |
Rep 699
Hello,
I installed a pbx yesterday and everything went ok (except I broke a tab on the left sensor - I ziptied it back). Drove for around 25 miles and then I got a light bulb with a exclamation point. Is this coincidence or should I check something with the pbx install? Thanks, Mike |
05-17-2011, 10:42 AM | #2 | |
Rep 1,111
When you start the car did it have some sort of abnormal revving? |
05-17-2011, 12:11 PM | #3 |
Rep 699
Car was and still seems to be running fine. Does anyone know if one of the wires we pull could actually cause this? Also, what is the left sensor for (the one you twist to take out in the beginning of the install process)?
I don't want to take it all apart again unless we can establish that's the probable cause. At first glance, it seems like all my lights are working. Thanks, Mike |
05-17-2011, 12:16 PM | #4 |
Rep 1,111
The fact you got an exclamation point warning means something is not hooked up right. I would highly recommend you go back in and make sure everything is snug. make sure all the connections you taped together with electrical tape is secure.
05-17-2011, 12:21 PM | #5 |
Rep 1,300
+1, you really do not not have any other options. You have a finger problem and you'll have to go in and fix it.
Brian
Black Sapphire, Black w/Burrwood Trim & Shifter, 162's, Mtec H8 AE's, DS1 HID 6000K |
05-17-2011, 12:28 PM | #6 |
Rep 699
Ok, I will. I just wanted to see if any of those wires could actually cause this issue. Also wanted to see if the sensor had anything to do with it.
05-17-2011, 12:38 PM | #8 |
Rep 1,300
Do you have a faulty exterior light?
Brian
05-17-2011, 12:42 PM | #11 |
Rep 1,300
Then I would suspect a common sensor issue and check the ECU.
Brian
05-17-2011, 12:52 PM | #13 |
Rep 1,300
Brian
05-17-2011, 09:28 PM | #14 |
Rep 699
Talked to burgertuning and they also stated it was coincidental. Good, though now I have to deal with a angel eye install. Seems a bit of a pain but oh well.
05-18-2011, 10:54 AM | #16 |
Rep 1,111
05-18-2011, 11:44 AM | #17 |
Came to the N55 Darkside
1115
Rep 12,740
05-18-2011, 11:46 AM | #18 |
Rep 1,300
Just as easy on an E90, just a litlle more time needed.
Brian
05-18-2011, 05:44 PM | #19 |
Rep 699
I have an e90 so I'm going to do it this weekend. Hopefully I can get to it easily enough without taking the tires off. I had gp thunders waiting to be installed anyway so it really is a relief that the bulb was the issue.
05-18-2011, 07:59 PM | #20 |
Rep 1,300
Take off the tires, it is much easier if you do.
Brian
