Help with 335i battery
Hi guys this is my first post onto this forum, I've been lurking here quite a while now. I need a little clarification with the battery in the back. I opened it up the other day to check the charge indicator turns it it wasnt green and holding sufficient charge, and because of that i had bad morning starts and wacky dashboard flickering while starting. I just bought a trickle charger and i am not sure where i should charge... do i charge it from the front where you jump start? or the back? also there are 3 positive terminals in the back which ones do i plug it into? Thanks for the help =)
