Driving hard to clean out carbon?
05-23-2011, 11:00 PM | #1 | |||
Rep 2,554
1. What are the symptoms of carbon build up?
2. What is the logic behind driving your car at higher rpms for an extended time? Here's what I got from the other thread. If you find the thread, you'll see that OP had some serious hicupping. Quote:
05-23-2011, 11:35 PM | #3 |
Rep 2,554
@Wallstreet,
Please keep the school comments to yourself. Last edited by username604; 05-23-2011 at 11:44 PM.. |
05-23-2011, 11:40 PM | #4 |
Rep 2,982
I've heard is theory before, yet cannot understand how it might work. All you will get is a lot more air flowing across the back side of the intake valves.
Oil from the crank case will still be filtered back into the valve area and cause issues. I don't care how much air passes across metal, it probably won't chip off hardened carbon. That stuff is hard to get off even with metal tools. I have no idea how people think sea foam or other methods might work. |
05-23-2011, 11:54 PM | #7 |
Rep 2,554
Ok so what exactly is effective (and easy)?
Also is there any harm if i drive the car @ 4k rpms for 10 min? |
05-24-2011, 12:35 AM | #9 |
Rep 2,554
this is all for future reference / curiosity. my car runs fine
05-24-2011, 04:10 AM | #10 |
Rep 3,552
it makes sense. if you want to clear out carbon, seafoam has been used for years. it also though no technically required, instructions say to drive the car hard for a period of time. essentially burning off the carbon. rev the crap out of it and let the fumes clean out your engine.
05-24-2011, 04:24 AM | #11 |
Rep 3,386
05-24-2011, 04:39 AM | #14 |
Rep 3,552
i would say for around 10 minutes. but make sure your car is getting fresh air. i wouldnt do it for more then 20.
05-24-2011, 04:54 AM | #16 |
Rep 14,829
Anyone try a banana in the tailpipes? j/k
I saw the pics of the carbon and thought dang, we all know the dealership is not going to make the effort to clean that well...would be nice to DIY if possible.... |
05-24-2011, 09:20 AM | #18 |
Rep 2,783
Just try Chevron Techron Fuel injector cleaner. Cheap and easy to do. Worked for my rpm fluctuating problem.
http://www.chevron.com/products/prod...tives/tcp.aspx
05-24-2011, 10:16 AM | #19 |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
Lol at this thread, here is how to clean the valves on the n54
http://www.e90post.com/forums/showthread.php?t=520922
05-24-2011, 10:22 AM | #20 | |
Rep 691
Leif W. |
05-24-2011, 10:30 AM | #21 |
Rep 2,982
guys, deposits form because gasoline is sprayed directly into the cylinder from above the piston. So your gasoline that has detergents never gets to pass over the air intake valves, keeping them constantly clean. You have to directly access your valves to scrape off the carbon buildup physically.
BTW, does anyone have photos of carbon buildup on an N54? I've seen it on E39 M5s and of course the god of carbon, the RS4, but I haven't seen how bad it can get on our cars. |
05-24-2011, 11:32 AM | #22 | |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
