Octane help
05-24-2011, 05:22 AM | #1 |
Rep 181
Octane help
im getting the jb4 tune with dual cone intake and up here in alaska i can only find 90 octane. will this octane be fine with the tunes that i have. help please, before i break something
05-24-2011, 05:47 AM | #2 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
use map 5, it will auto tune it self to the octane you have.
05-24-2011, 08:19 PM | #4 |
Rep 286
05-24-2011, 08:22 PM | #5 |
Rep 6,773
05-24-2011, 09:53 PM | #9 |
Rep 1,087
Drives: 2006 BMW 325i
05-25-2011, 02:01 AM | #11 | |
Rep 5,046
The obvious choice here is the go with methanol injection if you really want to tune and be safe. |
05-25-2011, 08:21 PM | #13 |
Rep 6,773
with the kind of temperatures the n54 sees that would still be risky..even more so if u r running a tune..running a tune on 91..is bad enuff but 90?..no way man sorry..meth injection is def the way for him to go if he has nothing else other than 90available
05-26-2011, 01:51 PM | #14 |
Rep 181
thanks for all the help, but the question is about the jb4 and the octane level. does it need to be at 93 octane or is there a safe mode with the jb4 where i would be ok running 90 octane because thats all we have up here in alaska? thanks
05-26-2011, 02:28 PM | #15 |
623lb puller
26
Rep 199
map 1, or autotune, i dont believe one octane point will make that much of a difference.
plus how hot does it get up there? i doubt not as hot in cali which only has 91.... |
05-26-2011, 03:29 PM | #16 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
map 1 would knock to death, map 5(auto tune) would be the best
05-26-2011, 03:39 PM | #17 |
Rep 7,089
Drives: '06 AW 330xi
05-26-2011, 08:05 PM | #18 |
Rep 6,773
05-26-2011, 08:14 PM | #19 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
Flash tune would be perfect, piggybacks require high octanes...
05-26-2011, 08:29 PM | #21 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
anyway even the op seems doesn't even know what he's asking...
Thread fail
05-26-2011, 08:31 PM | #22 |
Rep 7,089
A piggy back tune modifies the signal from the DME to the engine. It doesn't alter the DME itself.
A reflash alters the DME. Whether the company decides to take the adaptations out or not is up to them. I don't see why you would take it out though. The octane adaptation isn't just for adjusting to different octane ratings. It also adjusts to the mixture of the fuel. Not every tank you fill up is going to be exactly 93 octane or whatever you fill up with. |
