any manual owners find down-shifting not as smooth when using A/C?
07-11-2011, 01:44 PM | #1 |
Rep 1,082
kind of hard to describle, but when the ac is on and I downshift and let out the clutch, it seems to clunk a little or not let out as smoothly..maybe this has to do with the load on the engine and i'm not matching rev's good enough? anyone else know what I'm talking about?
It takes a big man to cry. It takes an even bigger man to laugh at him-- Jack Handey mods: blackout grill, finishing rods, badges, Blacklines. |
07-11-2011, 03:03 PM | #2 |
Rep 109
Turning on AC does place a small amount of extra load on the main crank pulley (where the AC belt attaches) but it's such a small amount that I would be very surprised if it would affect the way you downshift.
Without AC you would have to be rev matching so perfectly that when you turn on it on that tiny amount of extra stress would cause the RPM's to drop such a small fraction of an amount faster that it would mess up your rev matching....you are either A: A robot B: related to Mario Andretti Kidding aside, try rev matching at a slightly higher rev depending on your speed/gear, if that gets rid of the thunk then you'll know it's the AC. |
07-11-2011, 03:14 PM | #4 |
Rep 5,018
Drives: VALNCYA
its the CDV take it out
07-11-2011, 03:17 PM | #5 | |
AC
95
Rep 2,387
you need to give more throttle and rev the engine up more before you shift...
Your Supreme Leader
07-11-2011, 03:19 PM | #6 |
Rep 4,109
Drives: BMW M3
Yes there is a small difference when you use AC.
Solution: shift faster And get rid of the stupid CDV.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
07-11-2011, 03:35 PM | #7 | |
Rep 1,082
thanks!
07-11-2011, 03:35 PM | #8 | |
<3 Flat Four
217
Rep 754
ull have to either a: shift faster and let the clutch out faster before the revs drop, or b: rev a bit higher to compensate for the rpm drop
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White |
