Downshifting
07-12-2011, 10:20 PM | #4 |
Rep 270
you dont need to rev match, i do it because its smoother but its up to you, all depends on the way u like to drive really.
16 f10 535xi m sport - on its way
07 e90 335i - retired |
07-12-2011, 10:24 PM | #5 |
Trance Life
315
Rep 4,706
lol, i don't think rev matching matters unless you are racing? i downshift because it's fun...
Vanguard V2 Exhaust//Vishnu DCI//ACM Angel Eyes
07-12-2011, 10:26 PM | #6 |
World's Foremost Authority
1181
Rep 4,535
Drives: M4 Cab - Cayenne GTS - Jag XK
Location: Upper East Side Manhattan - Boca Raton FL - Lime Rock CT
Yes you need to rev match on a downshift. You may get away without rev matching when you are well below the limits of the car but it is nevertheless a poor techique. Poor driving techniques will eventually come back to bite you in the ass.
As an experiment downshift very quickly while going in a straight line. Do not feather the clutch (which is also a poor technique). The car will slow down very suddenly and there will be a lot of strain on the drive train and the clutch. This can cause the rear wheels to break loose as the weight of the car suddenly transfers to the front tires and the rear contact patches decrease in size and the front contact patches increase in size, When the clutch is depressed the engine drops to idle, then when it is re-engaged it has to spin the engine back up to the wheel speed using the clutch disk. This can cause undue wear on the clutch, but can also cause a loss of traction at the drive wheels, and even a loss of control. Racing instructors call it "trailing- clutch oversteer". Body shops call it a gift. "Blipping" the accelerator (i.e. rev matching) will eliminate this. CA
Drivers Club at Lime Rock - International Motorsports Research Center - Society of Automotive Historians - Madison Avenue Sports Car Driving and Chowder Society (0nly a VP) - BMWCCA - Porsche Club of America - M Gruppe - Polish Race Drivers of America (PDRA) - Glen Club (Watkins Glen International) - Jaguar Club of Southern New England Last edited by captainaudio; 07-12-2011 at 10:57 PM.. |
07-12-2011, 10:54 PM | #8 |
Rep 251
I always 100% of the time rev match my gears.
07-12-2011, 10:58 PM | #9 |
Rep 2,076
If you want your clutch and tranny to go out faster?? Common sense?? And it does depend a lot of the RPM, if your in 6th going 60 and drop it down to 3rd without double clutching, well thats just not good.
07-12-2011, 11:13 PM | #12 |
1181
Rep 4,535
I do too when driving an MT although it is not necessary to do so on a modern fully synchromeshed transmission. There is certainly no harm in double clutching and it is a habit that I got into driving racing transmissions with straight cut gears and no synchros.
CA
Drivers Club at Lime Rock - International Motorsports Research Center - Society of Automotive Historians - Madison Avenue Sports Car Driving and Chowder Society (0nly a VP) - BMWCCA - Porsche Club of America - M Gruppe - Polish Race Drivers of America (PDRA) - Glen Club (Watkins Glen International) - Jaguar Club of Southern New England |
07-12-2011, 11:13 PM | #13 |
Rep 5,538
its a must on track, but in daily driving you are not gonna put much wear on the drivetrain
but now that u started this thread I wanna try to get used to this......if I don't forget |
07-12-2011, 11:19 PM | #14 |
1181
Rep 4,535
As I stated previously a poor driving technique is a poor driving technique ane the fact that you may get away with it does not mean it is not a poor driving technique. Track or not if you downshift without rev matching when you are near the linits of the car, which can be at slow speeds on an slippery road, there is a good chance the the rear tires will break loose.
If you are going to drive an MT it is a good idea to learn how to drive one properly. CA
07-12-2011, 11:21 PM | #15 | |
Rep 203
07-13-2011, 05:45 AM | #16 |
Rep 699
I rev match for fun now i dont even notice that i do it.
2021 M2C HS DCT
2007 Wedge 335i E92 FBO, Stage 2 LPFP,VTT STG 2+, VTT Shotgun E50 w/ Inlets MT-SOLD |
07-13-2011, 06:30 AM | #17 |
Rep 95
Rev matching is not required, but i do it almost all the time during more than normal driving. It gives you smoother transition of slowing down much smoother without jerkyness. I started doing this back when i had MR2, which was notorious for bad syncros.
I dont get why people double clutch because i thought that technique was normally used due to lack of or worn down syncros, especially lower gear shifts. |
07-13-2011, 06:44 AM | #18 |
Rep 191
Driving is much more enjoyable when you don't worry about double clutching. I also never rev match but I also never do a massive downshift that would require one such as 5th to 2nd at 50mph for example, I only downshift into the appropriate gear which doesn't really require it.
07-13-2011, 06:51 AM | #19 |
Rep 2,084
When I'm coasting to slow down on the freeway, I don't need to rev match. When I downshift to accelerate, I do rev match. When I downshift 6 to 3 entering an off-ramp, I heel-toe. When I downshift 4 to 2 or 3 to 2 for a turn, I usually double-clutch heel-toe.
07-13-2011, 07:47 AM | #20 |
Slow,fast,slow, then you die.
12
Rep 243
I do everytime for 4th, 3rd, and 2nd. 5th is almost an overdrive and unless you are pulling a buck fifty there is no need. Of course don't ever downshift into 1st.
07-13-2011, 08:14 AM | #21 |
AC
95
Rep 2,387
you will clutch will need to be replaced more often than if you rev-match.
Your Supreme Leader
07-13-2011, 08:40 AM | #22 |
Rep 1,770
are u serious? really?
One of the posters in here was right about not rev matching.... it's much more stressed on a motorcycle because you can actually lock up your rear wheel and fall which is VERY easy to do. Of course now they have slipper clutches, but still.... is it that hard to blip your throttle? this is a BMW forum...I thought people actually knew how to drive.... |
