330d Misfire - Video Inside
07-17-2011, 11:13 AM | #1 |
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
Hey,
Our 330d misfires on cold starts. Think its injector related. When its warm, idle can be normal or slightly rougher than usual. It misfires most times on cold starts but varys in severity. Here is a video of this mornings cold start. http://www.youtube.com/watch?v=5zPk2Wg0Vf8
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
07-17-2011, 11:14 AM | #2 |
Rep 2,612
Sorry for the numerous posts - this App is useless! I'd say about 50% severity. When you start driving, all returns to normal. It sometimes fully misfires but I am yet to get a video of it - I will post a link back here when it REALLY Misfires.
Diagnosis please! 58k miles.
07-17-2011, 03:47 PM | #4 |
Rep 2,612
It uses glows - at the end of the day the fuel is being ignited the same as Petrol to push the cylinder down. There is a problem with one of the cylinders - evidently not firing correctly = misfire. The problem is the same. There is a smell of unburnt fuel.
07-17-2011, 04:30 PM | #5 | |
Rep 2,383
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
07-17-2011, 05:44 PM | #6 |
Rep 2,612
Does the 30d have a HPFP?
07-17-2011, 06:11 PM | #7 |
Rep 2,383
IMHO, because of the higher compression of diesel engines (necessary because there is no spark) they pretty much always run higher pressure fuel pumps (the heavier fuel might also require more pressure to get it to the right place). But diesel engines have the advantage in that their fuel doubles as a lubricant so the fuel system is generally more reliable. Another advantage of diesel is that has a higher flash point and can be tough to ignite in an accident (a pity because from the posts I see on this forum it appears that 335i owners would be more likely to take advantage of this feature than 335d owners).
07-17-2011, 06:32 PM | #9 |
Rep 2,612
Actual Rev Limiter is at 5000rpm. Red line starts at 4800.
07-17-2011, 06:37 PM | #10 |
Rep 2,612
We were going to wait till service (month or two) to have the problem sorted but the smell of unburnt fuel means I want it in ASAP. The unburnt fuel can contaminate the catalyctic converter, melt the catalyst and/or block the exhaust causing a vehicle fire.
So all the problems that 335i owners have with HPFP Failure all over this forum, can the same HPFP be related to the 30d?
07-17-2011, 09:16 PM | #11 | |
Rep 2,383
Funny, i dont pay much attention to the Tach since the 335d is an automatic and I rarely use the paddle shifters. So I can't recall where the redline is. Diesels run like bigger engines, everytime the crank spins it produces more power than the equivalent gas engine, so the crank just doesnt need to spin as fast to produce the same power.
07-18-2011, 08:05 AM | #12 | |
Rep 2,612
07-18-2011, 08:19 AM | #13 | |
Throbbing Member
43
Rep 1,433
Glows are only used to preheat the combustion chamber prior to starting the engine in extremely cold weather. Maybe there's a compression problem in one of the cylinders? More likely it's a fuel system problem though.
2014 Tesla Model S 85kwh
Previous cars: 2011 335d / Deep Sea Blue / Saddle brown / sport / premium 2008 BMW 135i / 6MT 2002 Z06 Corvette |
07-18-2011, 08:33 AM | #14 |
Throbbing Member
43
Rep 1,433
Yes, limited by the laws of physics, even the Audi race diesels shift below 5000rpm. Bigger diesels redline lower, like the 6.7L motor used in Dodge trucks which redlines at just over 3000rpm (350hp and 800tq)
07-18-2011, 09:59 AM | #15 | |
Rep 2,612
07-18-2011, 11:50 AM | #16 |
Rep 2,612
So why does the car run fine and normal when you start driving? This is a tricky one! Compression doesn't increase with RPM, just happens more often - correct?
08-25-2011, 05:17 PM | #17 |
Rep 2,612
Good news! Problem sorted It was a faulty Glow Plug Control Unit so a new one was fitted under warranty. Job's a gooden. Running on all 6 nicely again!!
08-25-2011, 09:22 PM | #18 |
Rep 2,383
Interesting, but arent glow plugs only used when the engine is really cold such as in colder climates? Was the Glow Plug Control actually activating them when they were not needed? So this could happen to anybody. Or did you need them when starting the car and they didnt function properly?
08-26-2011, 04:58 AM | #20 | |
Rep 2,612
08-26-2011, 04:58 AM | #21 |
Rep 2,612
Mmmm yes, that was mildly interesting!
