Uneven idle and lag in acceleration
07-22-2011, 09:22 PM | #1 |
Rep 34
Hi everyone, I have recently done valve cover gasket replacement on my BMW 325 E90. Since then the car behaves strangely - there is a carbon build-up on exhaust pipes, idle is jumping by 50 RPM and sometimes there is a lag when I am trying to accelerate from low RPM, as if there is an interruption in gas supply or something like that. I have talked to BMW dealers and they said about jumping idle that the tacho is too sensitive and there is nothing wrong with it, that I find nonsense, they could not replicate other problems. I live in Georgia, Tbilisi, so there is only one BMW dealer in the country.
07-23-2011, 11:27 AM | #2 |
Rep 1,011
check out the couple of threads above this one... the ones about ticking noise and rough idle...
i think youll find those handy since its kind of related to this issue.
driving is poetry in motion. |
07-23-2011, 12:25 PM | #3 |
Freight Dawg
104
Rep 2,103
You might have broken the PCV line that connects to the back valve cover. I have a thread on this it's gonna be near this one.
Edit: this - http://www.e90post.com/forums/showthread.php?t=561939
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors Last edited by e90pilot; 07-23-2011 at 06:38 PM.. |
07-26-2011, 02:57 PM | #5 |
Rep 34
Well, I have had my car scanned and there are no errors at all. I have changed spark plugs and checked the vacuum of the inlet and the whole engine. No leaks at all. Nobody can tell me what is wrong with it.
07-27-2011, 12:21 AM | #6 |
Rep 34
I have noticed that the probleb is associated with outside air temperature. With high ambiant temperatures the car jerks ant 1300-1800 RPM. Could it be associated with injectors or fuel pump. It still does not throw any codes
