      09-12-2011, 10:22 PM   #1
Lines in or out?
Better with or without the power lines?
      09-12-2011, 10:56 PM   #2
1013mm
aka 1013MM
1013mm's Avatar
Hong Kong
1347
Drives: pokingly flush
2009 135i  [8.26]
out but you have to take out the poles too or it just doesnt make sense
      09-12-2011, 11:26 PM   #3
TL
TL's Avatar
Drives: Happy on H&R coil overs
2008 335xi  [1.00]
it looks cleaner and open without
      09-12-2011, 11:27 PM   #4
I thought the same thing. But I was wondering if the overhead lines contributed to leading lines effect or were just distracting.
      09-12-2011, 11:38 PM   #5
TL
TL's Avatar
2008 335xi  [1.00]
the road to the right was already leading my eyes the power lines was more of a distraction for me and it made me split the photo from left to right
      09-12-2011, 11:39 PM   #6
Cleaner, but doesn't draw the eye as much, IMO.
      09-12-2011, 11:42 PM   #7
TL
TL's Avatar
2008 335xi  [1.00]
yea, i know what you mean
      09-12-2011, 11:44 PM   #8
oneintheory
no longer a BMW owner
Drives: 2011 Ford Edge Sport
honestly i don't find it a particularly strong image either way. there's no real subject, the light is harsh and flat, and the composition is pretty boring.
      09-12-2011, 11:46 PM   #9
hipnotic
hipnotic's Avatar
Drives: e92 335i
2008 335i coupe  [7.00]
without nice pics
      09-12-2011, 11:49 PM   #10
Thanks, Josh. I wasn't planning on entering it in a contest. Just wondering if it's de rigueur to remove powerlines or if they can actually contribute (in whatever small way) to an image.
      09-13-2011, 12:04 AM   #11
I n i T i a L
I n i T i a L's Avatar
Drives: 2011 128i
2011 128i  [0.00]
i agree, i actually like it a lot with the leading lines above,
maybe if u had more clouds or something, i would have considered it then, but what drew you to take that pic in the first place, i can imagine was the pole and the lines ....
either way, looks great!
      09-13-2011, 12:09 AM   #12
Actually, I had just taken some wide angle shots across the street and was waiting for the combine to make its way closer to me before swapping lenses to shoot some harvesting images. The combine is in that image, it's just too small to see. I just noticed the ditch, the road, and the overhead lines all converged. As Josh pointed out, though, they converge on nothing and the rest of the image is open space. But that is the whole point. We normally remove things like power lines running across an image, but doing so can sometimes subtract from an image (or not, that's what I'm asking).
      09-14-2011, 05:50 PM   #13
I n i T i a L
Drives: 2011 128i
2011 128i  [0.00]
gotcha Batman!
      09-14-2011, 06:46 PM   #14
The1
Drives: white 135
Honestly, if you stidestepped about 4 steps to the right, i could see the power lines adding to the image. They seem to be a little bit too over head to add to this particular image.
However, without the power lines at all, i think the picture looks a little too barren.
I've been having mixed feelings either way and wanted to be constructive, but the only thing i can see from my point of view is the side step and leave the lines in as they break up the negative space. And there is a fair amount of it available in this image.
      09-14-2011, 07:08 PM   #15
I agree. Negative space is what makes it so hard to capture the vast flatness of this area. There are several places I drive by on my commute where can you can see to the horizon 360 degrees. It makes you feel small, but the vastness is hard to capture with a camera. Out in the basin and range area of the west you can stand at the base of one range and shoot across the huge, flat expanse to the other range and convey the feeling just because of the two ranges. The near range gives you a lift above the floor of the basin and the far range breaks up the negative space. Out here it's just plain flat. And when you can stand in one place and see 10,000 acres of corn and soy, it's amazing. Just damn hard to capture.
      09-14-2011, 07:13 PM   #16
The1
Drives: white 135
I know what you mean, every time i shoot out on the lake it's like, "how can i make this more interesting.... It's blue, and blue, and a line across it. Maybe I'll get lucky and find a cloud!"
      09-14-2011, 07:27 PM   #17
Chewy734
Drives: 2006 BMW 330i ZPP, ZSP
Mark, if you have a similar photo with an object in the bg, you can prolly use it for the latest contest.
