10-12-2011, 08:58 PM | #1 |
Rep 416
Leveling a truck
Im about to purchase a 2007 Tacoma and want to level it out and buy bigger tires. Has anyone done this and know whats the most affordable route without sacrificing too much ride comfort since it will be my daily commuter and my bimmer a weekend car.
I see so many brands out there for levelers. Which brand is the most reliable? What tires give the most bang for the buck? |
10-12-2011, 09:23 PM | #2 |
Very Important
20
Rep 450
Drives: 335xi (e92)
Garage List 2008 BMW 335xi (e92) [9.00]
2008 Pontiac G8 GT [4.00] 2002 Pontiac Grand ... [0.00] 2001 Cadillac, Eldo ... [0.00] |
Z-Deck Truck Leveler Click above to view
Z-Deck Truck Leveler Sell Sheet Improve loading dock operations safely and cost effectively. Optimize your dock efficiency and safety by loading and unloading trailers above the building floor level. This minimizes interferences by the bumpers and building face. It reduces product damage and allows forklift drivers to have a better grade in and out of trailers. The revolutionary Z-Deck trailer lift raises trailer tires with a sloped deck that minimizes the angle of the lifting surface to keep the trailers from rolling away under their own weight. Designed to work with wall mounted vehicle restraints, the Z-Deck trailer lift matches the stroke of the lift cylinders to the vertical travel of a wall mounted restraint to increase the overall safety of the dock system. Increase Productivity Eliminate floor interference by safety lifting trailer beds above dock level for full, unobstructed loading operations. Low-Profile Design 2 Rear section slopes upwards to 8 at apex. No need for a costly in-ground pit. Maximize Safety The unique Z-shaped deck profile keeps tires on the deck and minimizes the slope the tires are supported by. Profile keeps tires angled towards dock to level at maximum raise. Simple Design Robust construction and dual lifting cylinders provide reliability and safety. Full-width Trailer Access Elevate trailers above floor level to service wider trucks with full-width loads. Improved Trailer Alignment Integral Wheel Guides center trailer on docks, minimizing product and door damage. Ski-Slope- the hinging action of a typical truck leveler pivots the front of the ramp and raises the rear causing a negative angle in relation to the dock. The Z-Deck Truck Leveler by Leum Engineering, Inc. is the only truck leveler on the market that can solve this very basic, yet dangerous condition. The mid-level profile slopes back toward the dock when stored creating a much safer condition. Due to the shock loads caused by forklift operations, a vehicle restraint is always safe practice. The Z-profile also increases the lift of axles that are further away from the dock face with a shorter lifting platform. Unique high-lift hinges at the front of the deck arc towards the dock creating a net vertical lift, minimizing the push away from the dock and again making the dock interface safer. The integral wheel guides center the trailer to optimize the door openings and minimize product damage. Using the lifting function to position the trailer bed above dock levels gives the operator full width access to the load and minimize product damage and increase productivity. Please Note: Unless specifically noted on quotation, all electrical including hook-up is the responsibility of others. Patent pending Nominal Dimensions The Z-Deck platform is 11 wide x 18 long Capacity AASHTO HS20-44 plus forklift for 60,000 lbs Construction The unit is constructed out of structural carbon steel consisting of 1/4 thick deckplate and structural HSS tube sides. The center tire surface is level from side to side to minimize interference with air ride brake canisters. The cylinders are nominally 16 stroke with a travel at the rear of the platform of 24. Hydraulics Dual 4 x 16 stroke cylinders with spherical bushings top and bottom to ensure long cylinder seal life. Loading Dock Bumpers Two 10 wide x 36 high steel faced dock bumpers are required (provided by others) Power Requirements 480v/3ph power with a 5 HP 3phase hydraulic power unit. Safety Features Z-Deck Profile Hydraulic Velocity Fuses Side toe guards Wall mounted retraint recommended Service Range 2 to 15 lift © Copyright 2008 Leum Engineering, Inc. All Rights Reserved. 952.401.0127 Sales@LeumEngineering.com |
10-13-2011, 12:36 AM | #7 |
Bootleggin' 'n Gunrunnin'
144
Rep 2,372
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
10-13-2011, 10:36 AM | #8 |
Rep 70
I'd go with camburg.com they have a sway away coil over and I think a fox coil over that easy bolt in that will give you 1-3" lift. It's valved for the truck and ready to go.
10-14-2011, 07:44 AM | #9 |
Look away, look away, look awa....
Rep 158
i did my own body lift on my 95 z71 and the newer leveling kits that Ive seen basically consist of a small spacer with bolt holes that go under/above (depends on the truck) your front coil springs. Nothing to it if you've got any sense whatsoever. Tires are a diff story. I like going for wider setting tires but the rims make the biggest difference.
I aint got time for all that "proper" grammar nonsense.
ROLL TIDE! |
