E90 se 320d exhaust mod
11-13-2011, 04:35 PM | #1 |
Rep 22
hi all newbie here will up load photos tomorrow...
just to start things looking at replacing the horrible diesel exhaust with a s/s twin port any recomendations or photos would be great thanks in advance... ps seen this on fleabay would this be a direct fit for an exhaust fitter of a big/expensive job http://www.ebay.co.uk/itm/BMW-E36-E4...item3a6c641f30 |
11-13-2011, 04:49 PM | #2 |
Dieseasal
204
Rep 6,881
Any exhaust place can fit this for you mate. Will need a custom piece of pipe from the stock backbox.
Expect to pay no more than £80-90 fitted for something like this. Might as well get the tips from the exhaust place too. I went to a powerflow dealer and ended up with this:
Previously: 2003 Peugeot 206 1.6 8v | 2006 E90 320d M-Sport, 19" BBS CH, Full Ice-cold JL audio install, August 2010 Total BMW 6 page feature car. | 2003 Nissan 350Z GT Coupe 286BHP
Now:2010 E92 LCI 335d M-Sport |
11-13-2011, 05:23 PM | #3 |
Rep 391
Ok I want to make it crystal clear, I'm not looking for an argument or anything of that sort.
Why would you or people want to put a custom exhaust on a 320d? I don't quite grasp it.
2007 330i M Sport Saloon Le Mans Blue .Active steering - Comfort Access - Bluetooth -TV - Heated Electric Memory Leather Seats - Auto - Logic 7 - Pro Nav - Adaptive Xenon Headlights BMW Assist - iPod integration - Swirl free |
11-13-2011, 05:52 PM | #4 | |
Rep 1,542
The standard droopy pipe that comes with the saloon is not exactly flattering. |
11-13-2011, 05:56 PM | #5 |
Rep 391
Oh I see, its aesthetics, I thought it was for like a racey sound or something.
My bad, as you were.
11-13-2011, 06:07 PM | #6 |
Rep 3,815
I would give BCS a call they do a good back box which is direct swap for the OEM oneand comes with twin rear ovals.
Changing a exhaust on even 320D does make a difference, apart from the fact the droopy one is pants and even the oval one on LCI cars is cheap and nasty and tarnishes quickly. The oval metal is very poor and looks tired quickly Putting a less restrictive back box simply makes the car more drivable IMO. I found when on load mine sounds less strained and is just easier to drive and spool up.
F30 335i M Sport - now departed
11-14-2011, 07:36 AM | #7 |
Rep 22
ok cheers for the advice althought when you say get the tips done as well what do you mean?
11-14-2011, 07:55 AM | #8 |
Dieseasal
204
Rep 6,881
Sorry, I meant buy the tips you want (as per your link) from the place you intend to fit. You're likely to get a lower overall prive for supply and fit compared with just fitting something you've brought along.
Also, if anything goes wrong or the part is wrong etc etc - it's on the exhaust place to sort out rather than you this way Magic77 does suggest a good alternative to just replacing the tips.. (full replacement backbox) but AFAIK you're looking at a good £350 or so fitted for a full replacement backbox rather than the £80 I mentioned to get mine done as per the above pics Hope that clears it up.
11-14-2011, 08:11 AM | #9 |
Major Pain in the Arse
11
Rep 347
11-14-2011, 08:28 AM | #10 |
Rep 438
The mv one above looks nice, I'm keeping my eye out for a 330 backbox on eBay, hopefully it will be easy ish to attach and still look factory
YMB M4
E93 320d Msport - sadly gone to the salvage yard. |
11-14-2011, 11:30 AM | #11 |
Rep 22
[QUOTE=Statler;10799014]Or you could do a DIY on the back box..
http://www.mvsport-tuning.com/ Easy to do sorry for being numb DIY exhaust you say is easy to do would it not need welding etc |
11-15-2011, 01:38 PM | #12 |
Rep 22
well i am confused now spoke to a powerflow dealer in bolton near me and he said due to the existing pipe being mild steel and a set of s/s tips the two different metals will not weld therefore my only option was a complete backbox £185 fitted inc VAT and my choice of pipes which doesnt sound too bad but is he right regarding the two types of steel?
11-16-2011, 05:31 AM | #13 |
Rep 3,815
it depends what you want I did removal of the mid box with just straight pipe and then a BCS backbox which is the same as Statlers. It worked about about £250 in total. You could just get the back box and cut the current exhaust yourself as it comes with a joining sleeve and you just need some pipe sealent to seal it
11-16-2011, 06:46 AM | #14 |
Rep 203
Just to clear something up gents.
The MV Sport backbox is produced by BCS and sold on for signafficantly more than what BCS ask for the original which was £200 to me, fitted for free at their workshop. Can't say fairer than that can you? |
11-16-2011, 07:15 AM | #15 |
Rep 3,815
thats very nice thing for MV to do. I went direct to BCS did not even know they resold it to MV at the time
11-16-2011, 08:12 AM | #16 |
11
Rep 347
NO welding!
DIY as in cut the old pipe with a hacksaw (or a 4" grinder...) and pop the new one on. You just need to get the car up off the ground a bit more, I used a couple of old railway sleepers and reversed onto them. If you can get it cheaper as per the guys above, fire ahead. |
01-03-2012, 03:23 PM | #17 |
320d M Sport Titanium Silver + a few cheeky extras
Rep 8
Hi Guys,
Would a new backbox such as the BCS one be OK in passing an MOT inspection? Even one at BMW dealer? (If that makes a difference?) Thanks in Adv. |
01-03-2012, 04:00 PM | #18 |
Rep 3,815
As long as its fitted correctly does not stick out past the bumper and is secured correctly no reason why it would not pass MOT
06-07-2012, 10:15 AM | #20 | |
Rep 32,881
I've just been to my local powerflow and they quoted £127 for exactly the same thing! |
