manifold swap question for 328i xDrive
11-24-2011, 10:04 AM | #1 |
Rep 472
Drives: E90 LCI 328i|E70 LCI xDrive50i
I have a 328i xDrive and just about to order 3 stage manifold parts.
am i good with these parts? 11617559523 Intake Manifold 11617559530 Vent Hose 11617579114 Adjustor Unit 11617560538 Adjustor Unit 2 11617547242 Gasket set 11617535850 x2 Screw 50x35 11617535849 x5 Screw 50x20 I'm not sure if the parts needed for the swap are the same as the 325i. do i need more parts or less? Thanks for your help!!
2013 VW Golf R | APR Stage 2+ 2015 BMW F06 640i xDrive | M Sport Edition | 20' Avant Garde M510 Retired 2009 E90 328i xDrive | M Sport | BMW Performance Grille, Intake, Exhaust, BBK | AA Stg 2 | 3 Stage Manifold | Bilstein Sport | Eibach Pro | OEM CF Spoiler | CF Lip | Alufelgen SF-71 |
11-25-2011, 10:21 AM | #2 |
Rep 472
anyone?
11-25-2011, 02:09 PM | #3 |
Rep 1,087
Drives: 2006 BMW 325i
The 328 has a different vent hose set up as I believe the oil seperator is located in the head (I could be wrong).
Go to realoem and pull up your make and model and find the "vent hose" that fits your car. All the other parts should be the same. |
11-25-2011, 02:19 PM | #4 |
Rep 687
Hey i just did one on a 328i race car, check it out. http://www.e90post.com/forums/showthread.php?t=614123
you also need: 11617535851 x1 50x66 hex head screw We didn't need the vent hose part #11617559530, but you may want to order it incase. You can always return it. I believe that hose is only used for the 325i. Who's doing your tuning? Good Luck! |
11-25-2011, 04:18 PM | #5 | ||
Rep 472
Planning on using Active Autowerke since i already have their tune. I have headers from MMW on the way too. Ess hasn't gotten back to about a 3 stage tune. I would like one with a module but oh well i guess. Where i live i dont have access to many tuners/ dyno's. I'm just too lazy to ship out my ECU, but i just might have to ship it to AA this time, cuz i just hate paying $650 for an AA tune in Edmonton What tune are you using?? ps sick race car
11-25-2011, 04:30 PM | #6 | |
Rep 472
11-25-2011, 05:09 PM | #7 |
Rep 687
Yes your are all good to go with the parts you have listed. Only part i saw that you are missing is the hex head screw 11617535851 x1 50x66 that is used on the back adjuster unit. The back adjuster unit uses 2 50x35 screws part# 11617535850 and the one i listed above. This racecar is getting a tune from O.E.
11-25-2011, 07:19 PM | #8 |
just another bmw douche bag
195
Rep 3,640
you should be able to reuse the stock vent hose on the 328i. But they are easy to break, so you might want to order a spare 328 vent hose just in case yours snaps, and then return it if you don't use it.
11-26-2011, 09:39 AM | #9 |
Rep 472
thanks for the help guys! Ordered my parts
08-04-2012, 12:46 PM | #11 |
***** noob
1376
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
need some help....
so I have a 325xi and got a used 330i manifold. The manifold has the vent hose already which is a 2 piece (see 1st picture from ECS part #11617559530). the pic from realoem is a 1 piece??? so do I still need to order another one? I already have one from the used manifold.
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
08-04-2012, 02:59 PM | #12 |
195
Rep 3,640
use what you see on the manifold, as it should have 2 spots to connect the hose (2 piece for USA 325i/330i). The realoem pic shows how the 530i 3 stage IM is set up with a single connection to the manifold.
10-10-2013, 12:53 PM | #13 | |
Rep 18
Thank you for the part numbers!!!! been looking everywhere for these!! |
