2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wash, Wax, Detailing and Cosmetic protection/repairs Detail addict-Platnium Addict, 2009 Camaro
      11-29-2011, 12:26 PM   #1
Elliott@DetailAddict
Drives: E90
We hope everyone's car is looking so great in the WINTER! Roll up your sleeves before the weather gets really bad, it will protect your car for awhile!
2009 Chevy Camaro
This car is only about 1.5 months old. The dealership did a very hacked job on it and filled EVERYTHING. It looked nice, but once we stripped everything, it was halogram EVERYWHERE. Although it's new, it has some very sever RDS and minor swirl marks. The entire process took about 20 hours or so...
Wash
Camspray Foam Gun
Detail Addict Water Softening System
Detail Addict Car Soap
Detail Addict Grit Guard
Detail Addict Wash Mitt
Detail Addict Waffle Weave Drying MF
Detail Addict Engine+Wheel Cleaner
Porter Cable 7424XP
Makita 9227C
Detail Addict Backing Plate
Detail Addict CCS Pad Set
Detail Addict Medium Grade Clay Bar
Detail Addict Detail Spray (lube)
Menzerna Power Gloss (S34A)
Menzerna Super Intensive Polish
Menzerna Super Finish Polish
Menzerna Final Polish
Detail Addict Sealant Wax
Miscellaneous
Detail Addict Glass Cleaner
Detail Addict Glass Towe
Detail Addict Rub&Shine
Detail Addict Dressing Sponge
Detail Addict Polishing MF
Detail Addict Detailing/Polishing MF
Sorry, it was very cloudy so no good pictures of "before"at outdoor that we can share with everyone... , but u can still the swirl marks in some of the pictures.
We start with the wheels and tires using P21 Wheel Cleaner and let it soak a bit
Off with a hand brush to get the spokes
Then with ACE PowerStick to get to the inside of the wheels
Recommended Products
Pressure wash off everything
Including the wheel wells
Then we start with the body to get the 'big dirt' off the car...
Hit the tires again as we rinse the body
Then off to our Camspray Foamer
You can never clean the wheels/tires enough!
Then off to two buckets hand wash with fresh MF
Then glide the water off of the car
Rinse down the wheels of course
Look at this! Brand new car! This is from just the hood too!
Air dry all the gaps and surfaces as much as we can
After air dry, we use Waffle MF to blot dry
Look closely, lot of RDS! We then took a paint meter to check the thickness and it was about ~145-185 micron all around. Plenty of paints on this car for correction!
and swirl marks
Still trying to perfect close up shots... But yeah, lot of swirls... Here are bunch of 50/50
Some indoor finishing shots
The sun finally came out the next day for us to take some outside pictures!
Best wishes!
      11-29-2011, 02:36 PM   #2
XDEEDUBBX
XDEEDUBBX's Avatar
64
Drives: 535I
great job as usual!
5post
