That time of year again....
12-01-2011, 09:56 AM | #1 |
Rep 284
With the recent influx of cold air over here in Ohio, Mid to low 30's F, it has made a huge difference on my car. I know the compressed colder air helps, but was wondering how much it helps.
Has anyone ever ran a dyno of their car in the cold or track times. I just have a JB3 (map5) and a BMS DCI, but my butt dyno tells me there is an even bigger increase than when it is running 60+ degree weather, just wasnt sure how much though.
335i E90 | BMS DCI | Black Matte Grill | JB4 | Logic 7 | Sport | Premium | Cold |
12-01-2011, 10:16 AM | #2 |
Rep 44
I am very interested in this as well.
Air at -30f is 17% denser than air at 70f. However, you're also starting 100 degrees rankine cooler in your V1*P1/T1=V2*P2/T2 calculations. This should help prevent knock with the denser air meaning that even with the increased mass of air the heat of compression will have a much lower starting temperature. If anyone here can confirm or deny this I would love to read it. |
12-01-2011, 10:50 AM | #3 |
Rep 15
Mustang dyno @ 81 degrees summer 2010 , 265hp, 305 ft/lbs
Same dyno winder 2010 @ 39 degrees 269hp, 318ft/lbs no mods between; but during winter tires become the biggest issue, snow tires, shit traction, summers under 32degrees...game over |
12-01-2011, 12:08 PM | #5 |
Rep 2,489
Drives: 2007 E92 SG 335i 6MT
normally, i have about 1000* weather. recently in the 65* weather ive felt HUGE improvement in torque!
12-01-2011, 09:10 PM | #6 |
Rep 284
Wow no that much of a change, my butt dyno felt at least a 100hp increase
12-01-2011, 11:23 PM | #8 |
Rep 26
All dyno's give corrected horsepower numbers. They take air temperature, pressure etc. readings and use a formula to calculate horsepower at sea level and a standard temperature. Your car actually making more power in cooler weather though just as it makes less at higher altitudes. Also turbo's benefit from the cool air.
