Battery - Leaving car parked in garage.
12-04-2011, 02:03 PM | #1 |
Rep 6,947
I have bought a winter runaround and as I am using it a lot I tend to leave the 335d in the garage more. Tend to take it out once a week or so to keep the battery up but get annoyed because then its dirty and needs a couple of hours cleaning again.
I'm sure it could sit for more than a week, anyone know how long its ok to leave it. Also what about some of these battery conditioners/ trickle chargers or whatever they are called. Anyone tried any of these and would not want to be spending a forture. |
12-04-2011, 02:43 PM | #2 | |
Rep 4,526
Optimate 4 Both abt £50 |
12-04-2011, 02:46 PM | #3 |
Rep 4,655
You won't need a trickle charger for 2-3 weeks mate. All you need to do is choose a decent day and make sure you give the car a proper run not only for the battery but also to promote DPF regeneration.
I used to leave my Boxster for that long and it didn't lose all charge - consider how notorious Boxsters are for drain issues and you should be able to take confidence. Matt |
12-04-2011, 07:06 PM | #6 |
Rep 1,661
My 5er has lived outside for the past 5 years with no problems until this summer when the original 2004 battery gave up the ghost. I have left it for 6 weeks in the winter and it never failed to start easily, even with the glowplugs on. My 3 will be subjected to the same abuse and I fully expect it to be the same.
Wife has one side of the garage for her car, so she doesn't have to chip her way into it in the winter, and my MG lives in the other side. Why, oh why didn't we build a bigger garage???? Mike |
12-04-2011, 11:39 PM | #7 |
Rep 2,216
Drives: E91 330d M Sport
Would you worry if you were going on holiday for a couple of weeks?
Unless your battery is dead, it will be fine.
Just how many Yorkshire sheep can you fit inside one exhaust?
12-05-2011, 02:22 AM | #9 |
The Tarmac Terrorist
951
Rep 29,345
Drives: 997.2 GT3
Ive left a car once for 6 months. It had 176000 miles on it and it was fine. Then again 3 months
997.2 GT3
12-05-2011, 02:35 AM | #10 |
Defected to the dark side.....
210
Rep 5,795
Drives: BMW M5 LCi
I use an optimate on my track car, keeps the battery in tip top condition by cycling the charge.
Once a battery has gone flat it's never the same IMO. |
12-05-2011, 03:00 AM | #11 |
Rep 6,947
Sounds like it should be ok, I just wondered because of the cold temps if it would run down. Having said that I have never had any hint of a laboured battery after letting it sit for up to 10 days. Will just need to keep taking it out now and again, had planned to drive it today but a bit icy and frosty here so best to leave it a day or two.
