Headlight Warning Signal ( CC-ID 88, CC-ID 89 )
12-05-2011, 01:32 PM | #1 |
Enjoying Everyday Life ~~
Rep 22
Hi All,
I installed the Xenons few years ago, and now I put back the original halogen. All the headlights are working, but I am getting CC-ID 88, CC-ID-89 warning signal pop up and the sound also .. almost every 15 seconds .. and it drives me crazy !!! Is there anyway that I can remove the signals ?? I followed the DIY on Halogen to Xenon conversion, and now I did it backward ... everything should be back to factory setting. Here is my terminal: 1 - Side Marker 2 - Empty ( removed the ground for xenon ) 3 - Low Beam 4 - Ground 5 - Empty ( removed the extra wire ) 6 - High Beam 7 - Empty 8 - Empty 9 - Empty 10 - Empty 11 - Empty 12 - Side Marker Do I need to go back to the Dealership and reprogram it ?? or just unplug the battery and let it reset ?? Thanks for all your help !! |
12-05-2011, 01:38 PM | #3 |
Rep 22
Thanks.
Actually, I didn't put the xenon programming after the conversion, the warning signal only showed up once for a while when I had xenon on. Now I put the halogen back .. it keeps showing the warning signal. |
12-23-2013, 11:46 AM | #5 |
Rep 49
I am also having the same problem i can not figure it out, i went to a shop to have it coded and the said they couldn't do it after keeping me there an hour
