330XI delayed power after shifting with 6MT
12-10-2011, 08:57 AM | #1 |
Rep 44
Hi all,
One of my childhood to now friends owns a nearly identical '06 330XI to mine. He has I Drive and I don't that's about the only difference. Last night he called me up and told me that he had no power after shifting for a few moments and then suddenly it would come back. I asked him to swing by but he was on his way to a gathering so he didn't come by. I'll get a chance to drive it today but I figured I'd vaguely describe the problem and see if it's happened before. Searching isn't turning up anything. |
12-10-2011, 09:23 AM | #2 |
Rep 4,488
Delayed power could be caused by the clutch slipping for a while after the it's been fully re-engaged, in which case it's probably time for new clutch plates. Easiest way to tell is if RPMs climb up a bit after re-engaging the clutch without much speed increase, then dip back down (the car might also slow a bit when this happens), and then the power actually comes on as they start to climb again.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 12-10-2011 at 02:34 PM.. |
12-10-2011, 02:42 PM | #4 |
Rep 2,554
put the car into third gear from a stop and if it stalls your clutch is okay. if it engages, your clutch is slipping. then again, i drive an automatic, so my advice is probably useless.
01-31-2012, 01:01 AM | #6 |
Rep 94
Drives: 335xi
hmm i have the same issue, only it doesnt seem to dip in the first three gears, the max lag/power drop seems to be 5th-6th. Or maybe i suck at shifting
