      05-21-2007, 02:33 PM   #1
Corey
Corey's Avatar
24
Drives: '92 240SX
blew my head gasket
"You're going to have your heart broken, and you're gonna repair it with zipties."
      05-21-2007, 02:38 PM   #2
Josh49
Drives: E90 325xi
www.bmwusa.com???
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER.
      05-21-2007, 02:42 PM   #3
Revlis
Now With 33% MORE Sarcasm Free!
Revlis's Avatar
Drives: M4 i3 X3
S 'Ok, I've blown a few head gaskets as well. It could be a DIY if you've got tools and skills.
If not, sux, cause it can be a little pricey.
A BMW is Just a Car, it doesn't make you smart, handsome, clever, better, cool, or wealthy.
      05-21-2007, 02:49 PM   #4
Corey
Corey's Avatar
24
Drives: '92 240SX
Originally Posted by Josh49 View Post
I think www.junkyardsusa.com may have a BMW in my price range
Yep, me and my dad are going to do the work. I think I'll replace the head bolts with studs while we're at it cause I doubt this will be the last time I'm pulling the head off, my engine doesn't seem to like autocross. Nikki's BMW on the other hand..
      05-21-2007, 02:53 PM   #5
Josh49
Drives: E90 325xi
Good idea. Good luck with the work..
You ever see the Seinfield were Jerry serves that one girl all of the wine and turkey so he can play with her toy collection...
      05-21-2007, 06:51 PM   #6
achien
AC
Drives: E90 Post Members Crazy
what did you do to blow your car's head gasket?
Your Supreme Leader
      05-21-2007, 07:03 PM   #7
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
He autoxed it, and it is a 92 sooo.. My car was really sweet in the autox though.
Nikki
      05-21-2007, 07:52 PM   #8
ward
Drives: F
head gaskets can also just wear out/break
I had a friend with a saturn (1996 iirc) and it blew a head gasket, and that thing was very far from ever seeing any type of competetive driving.
good luck on the fix, that job is a beeyotch, with the removal of so many parts!!!!!!
      05-21-2007, 08:22 PM   #9
jonerik26
jonerik26's Avatar
Philippines
59
Drives: black 335i e90 PRE-LCI
2007 335i  [8.00]
1998 Acura Integra  [8.50]
2006 325i  [8.00]
hahahaha!! i blew the headgasket on my 98 integra just last year......for that reason i got a 06 325i........
i did replace the gasket though....took me forever
      05-31-2007, 10:13 AM   #10
Corey
Corey's Avatar
24
Drives: '92 240SX
PICTURES!
Sometimes the breaker bar isn't enough!
New gasket
ME!
WOO NO MORE HEAD!
Moral of the story: zipties = win
Special thanks to NIKKI for the pics
      05-31-2007, 10:30 AM   #11
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
haah youre a jerk
Nikki
      05-31-2007, 10:54 AM   #12
Zeiss
Zeiss's Avatar
Drives: Bicycle
Looking good Corey.
What do you have planned for that? sr swap perhaps?
      05-31-2007, 11:12 AM   #13
DasBlitz
DasBlitz's Avatar
Drives: bmw 328i 07
2007 328i  [0.00]
Time for an engine swap.
      05-31-2007, 11:12 AM   #14
Corey
Corey's Avatar
24
Drives: '92 240SX
Originally Posted by BNR32 View Post
Looking good Corey.
t3/t04 50 trim .63 ar turbo
jgs manifold + 02 housing
jgs wastegate
z32 maf
550cc injectors
walbro 255 lph fuel pump
calumsult ecu
3" downpipe + exhaust
greddy m-spec fmic
Half of it's sitting in my room at home, the money for the other half went to rent Some day maybe
No thanks If it gets an engine swap it will be another KA after I blow this one up much worse than this
      05-31-2007, 11:49 AM   #15
Zeiss
Zeiss's Avatar
Drives: Bicycle
jgs wastegate
z32 maf
550cc injectors
calumsult ecu
greddy m-spec fmic
Sounds good man. Good seeing you are keeping the KA...
I'm getting very excited myself on starting my long awaited car project. (Lets just say i'v been educating myself these past years )
Here' s what i'm thinking of getting:
95 zenki
or the gts-t
Suggestions welcome...
Planning to do all the work myself. Compared to alot of people here, I'm not so keen on starting the drift basics just yet. Will be going towards doing some autox and track time.
Anyways, keep us updated man!
Cheers.
      05-31-2007, 12:53 PM   #16
Corey
Corey's Avatar
24
Drives: '92 240SX
I would personally go the S14 route because I have an unhealthy obsession with the S chassis for some reason.
It depends on how much work you want to put into it I think. 240s are fun but in stock form they aren't anything special. It would take a bit of work to match the Skyline's power and performance. It is a few hundred pounds lighter though. The Skyline would take less work to have a track ready car. Any reason for the GTS-t rather than the GT-R besides that I'm sure it's cheaper?
I like the S14 route because you can go in so many different directions with the car. KA-T, RB20/25, SR20, CA18, they even make LS1 swap kits now and you will end up with an awesome car no matter which way you go.
      06-01-2007, 11:17 AM   #17
Corey
Corey's Avatar
24
Drives: '92 240SX
This is why I don't work on new cars, this '92 is bad enough. After spending a few hours with the service manual I bring you this. Everything labeled green is emissions garbage and will be removed.
Back of the engine:
Lower intake manifold:
Upper intake manifold:
key:
A: Exhaust Gas Recirculation (EGR) Outlet
B: Vacuum Hard Lines to PAIRC Solenoid Valves (Atmospheric and Vacuum) and Canister Vacuum
C: EGR Valve
D: EGR Control (EGRC)-Back Pressure Transducer (EGRC-BPT) Valve
E: Fuel Pressure Regulator
F: Swirl Control Valve (SCV)
G: SCV Control Solenoid Valve
H: EGR and Canister Control Solenoid Valve
I: Idle Air Adjusting (IAA) Unit (Idle Air Control Valve (IACV)-Auxilary Air Control (AAC) Valve, IACV-Fast Idle Control Device (FICD) Solenoid Valve, Idle Adjust Screw)
J: IACV-Air Regulator
K: Solenoid Valve Bracket
L: Heater Return Hose
M: IACV Line
N: Canister Purge Line
O: Collector Coolant Line
P: Positive Crankcase Ventilation (PCV) Lines
To quote the great old_s13 from Zilvia on the EGR system:
"personally, i ditched all the logic and trashed the system long ago because it did nothing more than complicate my life and make it miserable. I hate that damn pipe in the back of the motor, its impossible to access and is always rusted on with exhaust crud. SO, goodbye egr.. goodbye aiv, goodbye charcoal canister -- hello empty engine bay. ECU codes? shit, ditch the check engine light while yer at it.. dont need that crap. want to check your engine? pop your hood, make sure its still there."
That's what I'm talkin about.
      06-04-2007, 11:46 AM   #18
Corey
Corey's Avatar
24
Drives: '92 240SX
It's alive.. and sounds like a weed whacker
