Codes P1553 and P1554
01-06-2012, 07:45 PM | #1 |
Rep 282
I have both codes active currently on my vehicle. There are multiple definitions for the codes. Has anyone encountered both of them at the same time. What fixed your issue. I also recently replaced my VANOS solenoids because i was getting a p0012 code, after swapping them it changed to a p0015 (its cam over retarded, 12 is intake, 15 is exhaust). Currently the car has limited power but I do not have the half engine light. Every once in a while the car will rev like it normally would. I am getting nothing but those 2 codes currently, no misfiring and the idle is smooth.
I am planning on buying a Bavarian Technic BT cable. So I can more accurately diagnose the car. |
01-06-2012, 08:48 PM | #2 |
Rep 40
Did you replace them yourself? If you did you probably forgot to program/initialize the solenoids to your car. i had the same issue once and i replaced and programmed and fixed the car
01-06-2012, 10:30 PM | #4 |
Rep 413
Im getting code P1553 and car would not idle rough then stall. Was that what you were experiencing with both P1553 and P1554 before you replaced both? I already tried cleaning it and didnt work. I plan on replacing them also. I did get code P0015 before but it went away.
01-08-2012, 11:38 PM | #7 |
Rep 282
I replaced both vanos solenoids, still no fix for the codes. ATM i am waiting on a BT cable to come in so i can do some further diagnostics. If i cant find anything solid myself I will take it to BMW.
01-21-2012, 07:01 PM | #10 | |
***** noob
1376
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
I also have p1553 and just clean the vanos
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
