E90 rear disc brakes drilled and grooved
01-21-2012, 09:04 AM | #1 |
Rep 9,097
Hi all,
Just wondering if somebody ever used Mtec brakes discs which are grooved and drilled. Its item number 300373803874 They also do black edition which is not listed for my car though. I am thinking of buying it for my car, as rear brakes need replacement according to OBC. Waiting to hear response from other users. Cheers. |
01-21-2012, 09:43 AM | #2 |
Rep 4,021
I take it the item number is an ebay number?
If you choose mtec discs buy direct from his own website as they are cheaper. Reviews on other websites seem to be reasonably positive especially for the cost. I've no idea how it's worth the guys time buying the discs and machining them for the cost he is charging. Last time I looked he was doing discs and pads all round for the 335i for £225. |
01-21-2012, 10:21 AM | #3 |
Rep 9,097
Thanks for your reply. Same discs are 10 pound expensive on their website.
On ebay you can also get cashback. So it works cheaper via e-bay. Anybody else given it a try? Cheers. |
01-21-2012, 12:14 PM | #4 |
Rep 365
Drives: F32 435dx ms, E90 330d ms
I used Mtec discs on my MR2 Turbo with EBC Red Stuff pads. Very good brakes. Couldn't fault them.
01-21-2012, 12:48 PM | #5 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
So these are standard discs drilled and milled??
I wouldn't put such a thing on a wheelbarrow, if so.
01-21-2012, 01:07 PM | #6 |
Rep 365
01-21-2012, 01:21 PM | #7 |
Rep 9,097
01-21-2012, 01:21 PM | #8 | |
Rep 4,021
What is your issue with them? He does not charge much for them and users seem happy. |
01-21-2012, 03:54 PM | #9 |
Rep 365
The theory is that the drilling and grooving (i.e the post production machining) affects the tempered metal which can lead to fracturing, cracking and/or warping of the discs. I've never personally seen this happen if the base product is of a suitable quality.
I believe some Porsche discs are made in this way. |
01-21-2012, 04:07 PM | #10 | |
Rep 4,021
Likewise with holes and slots prior to heat treatment the heat build up around those areas would be greater. Once the disc is at rest, surely that's the safest time to groove, drill or slot? |
01-21-2012, 04:28 PM | #11 |
Rep 365
Exactly. Aslong as the machining work is done properly with quality tools at the right speeds so as not to 'burn' the metal then there should be no problems at all.
01-21-2012, 04:46 PM | #12 |
LSD - No, you're not seeing things
72
Rep 3,302
Except that the original design (tested for TUV etc) didn't have scope for further engineering.
How do you know the modification doesnt affect the integrity of the original product, as it was designed without these weaknesses? In short, you are guessing. But I'm sure you'll be fine. Just hope you don't have to justify it to, say, an accident investigator.
01-21-2012, 04:52 PM | #13 |
Rep 8,693
Drives: 06 330i
stay far away from cheese grater rotors (drilled) that will eat your pads.
what point is drilled rotors when they get clogged with brake dust? |
01-21-2012, 04:57 PM | #14 | |
Rep 4,021
The structure of the disc will be poor to start with. Putting small dimples and shallow grooves will make very little difference in the structure of the disc. |
01-21-2012, 05:36 PM | #15 | |
Rep 9,097
In theory these brakes should give you better braking power under stressful conditions and many reviews on different forums confirms it. So far I came across one complaint where black edition disc colour melted and stuck on pads (after parking the car) but as soon as the company identified the batch, they sent replacement to all the buyers with pads for free and for some customers. I am inclined to give it a try, especially when they are cheaper than OEM product but not cheap enough to be considered as 'poor quality' parts. |
01-22-2012, 01:38 AM | #16 |
112
Rep 5,541
Very well said m1bjr, I just couldn't be arsed to type that sort of reply out
01-22-2012, 03:03 AM | #17 | |
Rep 9,097
Never mind, we all are different. Last edited by makkan00; 01-22-2012 at 03:22 AM.. |
01-23-2012, 02:19 AM | #18 |
Rep 8,095
I had some cross-drilled discs on my 944 but they were dusty and very noisy - stock was better in the end.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
01-23-2012, 02:44 AM | #19 |
Rep 136
Years ago I bought EBC discs and pads for my RX8 and I started getting vibrations when I was braking from 70-80mph.
I took it in to a indy garage and was told it was because they were grooved and drilled and he has seen loads of 'boy racer saxos and corsas' with the same complaint when they upgrade the discs. He said mine weren't that bad and they were quite noisy so other people complaining about them must have had a nightmare. Not sure what cars that come standard with groove/drilled discs do different or if the indy garage was giving me a load of bull??
01-23-2012, 03:49 AM | #20 |
Dieseasal
204
Rep 6,881
Erm. Drilled/slotted discs are fine.
I'd go EBC though. This topic is amusing.
Previously: 2003 Peugeot 206 1.6 8v | 2006 E90 320d M-Sport, 19" BBS CH, Full Ice-cold JL audio install, August 2010 Total BMW 6 page feature car. | 2003 Nissan 350Z GT Coupe 286BHP
Now:2010 E92 LCI 335d M-Sport |
01-23-2012, 05:39 AM | #21 | |
Rep 9,097
thanks for warning, and I was looking for such critical things. |
01-23-2012, 05:41 AM | #22 |
Rep 9,097
