E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Charging Malfunction- Help!
Reply
      01-31-2012, 09:19 PM   #1
StephenAHeck
Drives: 2007 335
Bought a new battery for my 07 335i in October 2011 but was not aware I needed to register it. I received 'charging malfunction!' messages about two weeks ago so I brought it to an independent BMW mechanic who registered battery. Mechanic did tests on alternator which appeared to be ok. Registration seemed to solve problem, as no messages appeared for a couple weeks.
Not so fast. They have appeared again. Also, the engine seems to turn over slowly when started. Is this an IBS problem? I'm taking it to BMW dealer tomorrow but would appreciate any feedback/suggestions. Thanks in advance.
      01-31-2012, 11:26 PM   #2
queensfield
Drives: 2006 330i E90
Check all wiring in the battery compartment- may be something came off or is not making good contact, if alternator is ruled out. IBS is also a possibility. What is the exact code you pulled from OBDII?
      02-09-2013, 07:21 PM   #3
Ark10bimmer
Drives: 2010 335i xdrive
Sorry to bring this thread back. But my car is showing charging malfunction. By the way it is a 2010 e90 335i xdrive. It has the AGM battery. Why is it showing it? Are there any signs if a bad alternator? I can not get it tested because the car is in the process of being fixed.
      02-09-2013, 10:57 PM   #4
Ark10bimmer
Anyone? I'm really worried.
      02-10-2013, 09:13 PM   #5
skeetx3
Philippines
Drives: e92 328i
Had the same issue as you, turned out to be the alternator. Basically with my issue it was bouncing from 12, 14, even as high as 16 volts while running. It threw a lot of codes as well. My dash lit up like a Xmas tree while driving and the speedometer would even cut in and out. Long story short after it was replaced no more issues AND it got rid of the rough idle I was having when I was at idle. It stays at a constant 600 rpms now. Hopefully they figure your issue out.
      02-10-2013, 09:48 PM   #6
Ark10bimmer
It's charges sometimes. I am putting a charger on it. And it won't start on its own I have to jump start it. In starting to think that a ground wire came loose or the ibs sensor.
Reply
e90post
