E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > 2006 325i Crankshaft Position Sensor Replacement
Reply
      02-01-2012, 08:18 AM   #1
correll24
Correll24
Drives: 2006 BMW 325i
Diagnosis: Car took several seconds to crank. Idle was rough. Stuck in failsafe mode (2nd gear). Battery was not charging.
Advanced Auto ran the codes and it came back with Crankshaft Position Sensor and Transmission Control Sensor.
Pain in the ass to change... Forget it, if you have fat fingers or hands.
The crank sensor (cost $120 with new bolt) is located under the starter (which is under the intake manifold).
Access the sensor from under the car on the driver side.
This is a one handed, blind job. you have to do it all by feel.
you will need an 8mm socket to remove the tork bolt.
one little turn by the wrench and you should be able to remove the bolt with your fingers.
remove the old sensor, also remove the rubber gasket and reinstall it on the new sensor.
I hope this helps some people, as I had the worse time in trying to find the sensor and instructions on how to do it.
overall, it took me over 3 hours to this 20 minute job.
Good luck if you try to tackle this one.
      02-01-2012, 09:06 AM   #2
Chriztofor
Chriztofor's Avatar
Drives: '06 325i and '13 X5
Thanks for the post. I like reading useful tips instead of complaints or problems. This board gets depressing at times.
      02-01-2012, 11:30 PM   #3
queensfield
Drives: 2006 330i E90
Lovely, great to know. Congratulations on getting it replaced. How many miles on yours?
      02-16-2012, 07:50 AM   #4
correll24
Correll24
82,500 miles
Running great after the replacemet!!!
      06-19-2012, 12:11 PM   #5
gwake1
Drives: 2006 325XI
2006 BMW 325xi  [0.00]
Part Number?
Reply
Tags
crankshaft, failsafe, position, sensor
e90post
