02-18-2012, 02:15 PM | #1 |
Rep 5,803
Halogen to LED DRL conversion
It says the DRL lights use a PW24W halogen, i found these LED's that are replacements for halogens...im pretty sure this would work bu was wondering if anyone here more technical than me had any input.
http://www.bimmian.com/70/WTS/ I might buy these and give them a try. I will call first and make sure i can return them if they dont work/throw a code. I think these might look cool and for 70 bucks is an inexpensive DIY
F30 330i Alpine white/Coral red Msport 6MT
02-18-2012, 03:10 PM | #2 | |
Rep 1,879
Drives: 2012 F30 328i
02-18-2012, 04:54 PM | #3 | |
Rep 2,377
Drives: Perfomance Model 3
'18 Tesla Perfomance Model 3 White on White Performance Upgrade Pkg & EAP
*RETIRED* 2015 435xi GC [f36] | 2012 335i [f30] | 2009 z4 35i [e89] | 2007 335i coupe [e92] | 2001 325Ci [e46] *RETIRED* |
02-21-2012, 02:49 PM | #4 |
Rep 5,803
Will probably order this tonight or tomorrow, will post pics of the before and after
02-21-2012, 02:54 PM | #5 |
Rep 173
Justin - Are there any bulbs available for the rear tail-lamp which are not LEDs? I am going to replace them if I can. Let me know Cheers. Btw, do Xenon's on the 335i also have these same bulbs? if so, i amgoing to order these... $70 is not terribly expensive.
02-21-2012, 03:02 PM | #6 | |
Rep 409
Looks good dude great find!!!!! Since you just got your car will BMW void warranty if you do that? |
02-21-2012, 03:25 PM | #7 | |
Rep 5,803
I have read up on that warranty stuff, they cant void me for just replacing a light bulb(at least i dont think they can). If i was doing an engine tune, or downpipes or something then yea, probably. If they give me any shit ill go nuts on them lol.
02-21-2012, 03:28 PM | #8 | |
Rep 409
02-21-2012, 03:29 PM | #9 | |
Rep 96
02-27-2012, 07:55 PM | #10 |
Brotographer
88
Rep 1,741
I'm sorry, but don't get those bulbs. Bimmian overcharges for EVERYTHING.
If you go to HighPerformanceBulbs.com, you can get their 18-LED bulbs that will fit these cars for $50 (http://www.highperformancebulbs.com/bmwpy5frtusi.html). And you can get the 23-LED version for $60 (http://www.highperformancebulbs.com/bmwpy5frtusi1.html). If you're willing to spend $70, get something that will blow both lower-end HPB products, and the overpriced Bimmian product out of the water. Get the 7.5 Watt LED bulb (in amber here http://www.highperformancebulbs.com/bmwpy5amulhi.html and in white here http://www.highperformancebulbs.com/bmwpy5ulhipo.html) and they will be SOOO much brighter than the cheaper bulbs. No one else sells those 7.5 Watt turn signal bulbs by the way. HPB has a great reputation over on E90Post for having rock-solid HID kits that won't throw errors, and they have an almost perfect track record on the pick 06/07 models too. Everything I've bought from them (interior kit for my car + friend's cars, AE's, turn signals, etc.) has exceeded my expectations, and their customer service is incredibly helpful for an extremely small business. |
02-27-2012, 08:00 PM | #11 | |
Rep 5,803
-will it throw a code? -how hot will the get, they are made for turn signlas, ut being DRL's they would be on for a while -how easy to install? i got into the area i need to install and its tight as hell in there also. what would the return policy be? i will be calling this new place tomorrow, thanks again!
02-27-2012, 08:12 PM | #12 | ||
Brotographer
88
Rep 1,741
2. They will certainly get hot, but they're clearly designed for it--note the all-aluminum construction. It won't get nearly hot enough to melt the housing, that's for sure. 3. I haven't seen an F30 yet (might be going on a test drive tomorrow though!!) so I can't say for sure; however, I bet there will be plenty of room--just pop the hood and take a look! |
02-27-2012, 08:52 PM | #13 |
Rep 710
WOW GOOD FIND!
I almost wanted to put off buying ht MY12 till BMW came out with LED lights in the F30. Just check out this video which shows the difference between the crappy bulb and sexy LEDs: |
02-28-2012, 08:34 AM | #15 |
Rep 814
How come LED bulbs are made to replace fog light halogen bulbs and every other bulb on the car but they're not designed for the regular driving headlamp halogen bulbs? In other words, the lights that really matter.
I'm clueless when it comes to LED bulbs. |
02-28-2012, 09:12 AM | #16 | |
Rep 784
Notice that the LED replacements have multiple small LEDs mounted on a cylinder to generate ~same total light output as the halogen. This is fine if you just need light that gets scattered in multiple directions for turn signals, brake lights, etc., but not so good if you need to create a beam of light. |
02-28-2012, 09:46 AM | #17 |
Rep 397
Drives: 11 E90 M3 ZCP
Guys,
I am bit of an LED nerd and have designed custom solutions for a few cars. Let me just say this, the majority of drop in LED bulbs are sub par and won't come close to matching your stock halogen output. LEDs by nature have a narrow output angle so they may look ok from straight on but output drops significantly when you stray from direct line of sight. This is why most OEM LED lighting solutions employ custom optics/reflector solutions to maximize viewing angles. The only semi drop in solution I have ever seen that exceeds halogen output are the 5W LEDs from ELEF http://elef-usa.com Elef's solution will reuqire you to splice you OEM wiring harness and possibly add relays to get them to function correctly. I would jsut be concerned with BMW's bulb checking functions and also if this would have any affect on the Active Brake Light system (If you choose to replace your brake lights). Still kills me that BMW didn't offer a full LED lighting solution from factory! Video of ELEF turn signals vs a drop in tower solution: |
02-28-2012, 10:00 PM | #18 |
Rep 1,879
wow thanks for this! I'm so going to change my indicator bulbs with the LED's like this, such a huge difference!
F30 328i Luxury w/ Mojave metallic, beige interior (timeline)
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread |
02-28-2012, 10:50 PM | #19 |
Rep 814
I don't understand the whole white indicator bulbs thing. Isn't that illegal in the USA? Are people that desperate for attention? That would be very very distracting to my eyes if I ever saw that on the road. Individualism should never be achieved at the expense of the public's safety, IMO. It falls in the same category as people who put those annoying blue bulbs in the headlights or put neon ground effects under their cars.
02-29-2012, 01:09 AM | #20 | |
Rep 1,879
And yep, it is illegal from what I know but so are the amber colored ones if they are not DOT approved (well, at least here in Hawaii). If it really makes a big difference in safety, I don't know. I do know the video stated that it is dramatized so it might not be as bright as it looks in the video. Either way, once I get my F30, I am going to order amber ones, not the white ones. Take, for example, the indicators in the mirrors, those are amber colored too, if the ones up front all the sudden are white, it's going to look very odd imo.
02-29-2012, 01:13 AM | #21 |
1ST CLASS AWMSPORT
74
Rep 789
Drives: 13' 328 MSPORT
I like the LED , did it throw any codes? do they make them in White?..(IMO i hate orange)
'13 328i MSport, AW, Black Dakota leather, Premium Pkg, xenons, ///M Perf, side skirts,Front Lip, Fully coded, CF roundels, Matt Black Grillz, Painted reflectors (front & rear) Smoked tail lights, Plazma l.E.D White PY27W front turn signal,trunk spoiler, Matt Black roof, 8K D1S HID,Custom Exhaust,!
Soon: JB4,DP,H&R sports,rear diff,! |
02-29-2012, 05:20 PM | #22 |
Rep 2,183
Drives: .
Garage List 2018 Audi RSQ3 (8U) [0.00]
2022 BMW X3 xDrive3 ... [10.00] 2015 BMW M235i (F22) [10.00] 2017 Mini Cooper S ... [0.00] |
