F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Need help on changing Xenon bulbs
Extreme Powerhouse
      03-01-2012, 04:40 PM   #1
joe07328xi
BMW forever
joe07328xi's Avatar
Drives: 12 F30 335i 08 E90 M3 AW
Anyone know what model of Xenon bulbs are the F30 using?
Anyone know how to change it?
Thanks in advance
2008 E71 X6 3.5i sold 2008 E90 M3 AW sold
2008 E93 M3 AW sold 2011 F10 535i SG sold
2012 F30 335i 2014 F25 X3 AW
      03-01-2012, 05:29 PM   #2
justinnum1
Drives: 2018 330i Msport 6mt
why are you changing them? and to what?
F30 330i Alpine white/Coral red Msport 6MT
      03-01-2012, 05:44 PM   #3
joe07328xi
BMW forever
joe07328xi's Avatar
I just want to change the bulb to 6000k
      03-01-2012, 05:52 PM   #4
DrivenByE30
DrivenByE30's Avatar
France
592
Drives: '12 F30 Lux 335i 6MT
you are going backward in time ... ?
      03-01-2012, 06:49 PM   #5
ƒ°
ƒ°'s Avatar
101
Drives: ✚
      03-01-2012, 06:53 PM   #6
justinnum1
6000k? what are they stock?
      03-01-2012, 06:55 PM   #7
ƒ°
ƒ°'s Avatar
101
Drives: ✚
They should be 4,500k - 5,000k. He wants to go bluer.
      03-01-2012, 07:03 PM   #8
justinnum1
Id be worried about it throwing a code. Let us know if you do and how it looks
      03-02-2012, 12:25 AM   #9
Blake P
Kinda Like A Big Deal
Drives: F31 on order
I tried 6000k once and the reduced visibility was not worth the "cool factor," IMHO.
      03-02-2012, 01:41 AM   #10
E90Fleet
South Africa
1312
Agreed
BMW if you are reading, I need a job, Please.
      03-02-2012, 01:41 AM   #11
E90Fleet
South Africa
1312
F30uses teh same Xenon bulbs as the E90
D1 bulbs
      03-02-2012, 01:44 AM   #12
longtran@ltbmw
longtran@ltbmw's Avatar
392
Drives: 2011 Toyota Tundra
if you use cheap bulbs, that would happen or if they were halogen bulbs, yes it would be dimmer. What brand were you using?
      03-02-2012, 07:17 AM   #13
Accelerometer
Accelerometer's Avatar
Drives: 11 E90 M3 ZCP
That is not true. HID bulbs with a higher color temperature will produce less usable light.
      03-02-2012, 11:59 AM   #14
Blake P
It was a while back so I can't remember specifically, but it was definitely a name brand... Philips or PIAA, IIRC?
And no, it wasn't a conversion kit. Direct HID bulb replacement in OEM projectors.
      03-02-2012, 10:56 PM   #15
joe07328xi
BMW forever
joe07328xi's Avatar
ok so its D1S same bulb used in my F10. Its a little bluer and not as bright but i am used to it. Anyone know how to replace it??
Joe
      03-02-2012, 11:51 PM   #16
justinnum1
Joe
in the manual
      03-03-2012, 09:39 AM   #17
jrob
Bimmer God
Drives: 2003 BMW 330i
You shouldn't get any codes by replacing the bulbs. However, the higher the color temperature the less visible light output. 6000k usually has a slight purple tinge to it and 8000k is slightly blue although it does depend on the bulb. The projector lenses can amplify the color hue a bit as well. I wouldn't go higher than 6000k as the light output really starts to drop off. That being said, I have 8000k on my E46 but I also have xenon fogs that help make up for less visible light on the road.
      03-03-2012, 10:20 AM   #18
cjh
Drives: 22 G42
For reference:
4300K is really the sweetspot for light output. Anything higher and you're decreasing your visibility.
      03-03-2012, 12:58 PM   #19
joe07328xi
BMW forever
joe07328xi's Avatar
anyone know how to replace the bulb yet???
      03-03-2012, 01:44 PM   #20
Blake P
I bet if you just keep asking every day, someone will eventually know.
      12-12-2012, 08:17 PM   #21
awhk
Drives: 2023 iX M60 SBM
Joe, any luck on changing the bulb?
I was able to access the headlight cover by removing the plastic panel on the wheel liner. After removing the cover there is a metal clip holding the D1S bulb but I wasn't able to unclip since the space was tight for me to access (probably need to remove the front wheel and jack up the car for more room) and I didn't wanna force and break anything.
      12-12-2012, 09:46 PM   #22
Blake P
Same awhk from Audizine?
f30post
