BMW E46 M3 - Legend Eternal
E46 M3 Coupe and Convertible Forum General E46 M3 Forum
      03-28-2012, 11:48 AM   #1
daltb
Drives: blue 2003 m3
Can someone please help me
I own a 2003 m3. Recently I installed new tires, tires of the exact size as the former. Now my loww tire pressure indicator light will not go out.
the following are the steps i have taken to eliminate this problem
  • Pressed the reset button, it goes off and then on again
  • Pressed the reset button when car was in motion no result
  • pressed the reset buttom when car was stopped no result
  • turned the key to the number 2 position pressed the reset button no result
  • disconnected the battery over the winter then reconnected and pressed reset button, no result
    • waived a dead chicken over my head while chanting Joan Biaz songs no result
    now this is an enthusiast car owed by enthusiasts do you think hard core car people know how to use a hand held tire pressure guage.... yes.... why then do they install an item that is pure aggravation
    Does anyone know how to solve this issue or has anyone had a similar problem
    thankx to all for your help
      03-28-2012, 05:06 PM   #2
ThunderMoose
Drives: PY E46 M3 and SG E46 M3
Low pressure is determined by change/difference in rotational speed on the E46 M3s.
You should be able to Start the car and hold the Tire Reset for 2-3 seconds. I can't remember if you hold until it extinguishes or whether it extinguishes after you release. You should plan to drive right away for a while (I am assuming to "lock" in wheel speed. Make sure you have checked your pressures and set according to manual or door.
The above procedure has worked for me. If that don't work, I'd just ignore until your next dealer visit.
      03-28-2012, 06:36 PM   #3
Singletrack
4th down; 4th quarter? Renegade.
Singletrack's Avatar
Drives: 09 SSII E92 M3; 19 FG M5C
It's in the manual.
You just reset it and then drive off. The light will go out in like a mile and now it has recorded the new tire pressure.
If this isn't working, it's possible the shop damaged the TPMS transmitters. I guess a really low pressure might make it error out potentially...or an excessively high one, although I've never tried.
What is the tire pressure?
Also, why didn't the shop reset it and verify that it was working? Any good shop should do this.
Also - from what I understand, BMW had a superior system that would actually tell you the tire pressure per tire as opposed to just green or red. It did not meet the "idiot use level" required in the US. So I guess you can blame us for the overly simplistic design.
e46m3
