E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Diesel Engines
Reply
      11-03-2005, 01:00 PM   #1
Broken1
Addict
Broken1's Avatar
203
Drives: 2024 X5 40i M-Sport
Diesel Engines
Okay, So I've been happily driving my 320d for almost 5 months now, and since the new car "whoopies" are wearing off, me and my car are getting better aquainted.
I've spent alot of tonight reading a FAQ on TDI's which speaks mainly of VW TDI's using direct injection. My car uses common rail technology if I understand correctly...
the TDI FAQ also mentions that diesel engines don't have spark plugs? That's rather interesting...
Can any diesel heads shed some light on the diesel engine, or point me towards a website that does? (Particularly BMW's and not VW's)
Out of interest, the site I am reading is tdiclub.com/TDIFAQ
Thanks....
Another interesting point the site mentions... Diesels engines do NOT heat up if left to idle.... who knew? Is this true for the BMW?
I want to know more about my car...
      11-03-2005, 01:01 PM   #2
Frank_NJ
///M Specialist
Frank_NJ's Avatar
Drives: E30 M3, E52 Z8, G83 M4Cx
What type of information are you looking for?
2023 M340ix my Daily Driver
G83 M4CV, F80 M3 CS, E30 M3, Z8, other various BMW's
Ferrari F8
      11-03-2005, 01:09 PM   #3
Broken1
Addict
Broken1's Avatar
203
Any interesting information on the workings of the BMW Diesel engine - what makes it different to a petrol engine etc...anything really that relates to my E90's diesel engine...
How the pistons works (apparently on compressed air and no spark plug?)
Intercoolers? Turbo charges?
      11-03-2005, 01:12 PM   #4
ZenDriver
Do Not Taunt Zen Driver.
ZenDriver's Avatar
12
Drives: 325i w/ MT, ZSP in Graphite
http://auto.howstuffworks.com/diesel.htm
Really well written primer.
      11-03-2005, 04:30 PM   #5
E90Fleet
South Africa
1312
You have a Turbo Charger, with variable vanes
You have a Intercooler
You dont have spark plugs, diesel self ignites due to high compession, but you hvae glowplugs to help when engine is cold
You have a diesel catalitic converter
Your fuel pressure is about 1,600bar
A BMW 4 Cylinder Diesel Engine
      11-03-2005, 06:22 PM   #6
voltron1011
voltron1011's Avatar
119
Drives: 2011 135i, FJR-1300
Diesel motors are compression motors that don't require spark plugs. Since the motor compresses the air so much (so hot) with aid of a VNT turbo, all that the hot air needs is some fuel to ignite it. Diesel motors don't have such violent explosions during combustion like traditional petrol motors, but rather a softer flame-up. This is why diesel motors can't rev super high. The glow plugs that you hear about are only needed when the motor is cold.
      11-04-2005, 01:35 AM   #7
Broken1
Addict
Broken1's Avatar
203
Thanks
Now....with this common rail thing? Is that how the fuel is sent to the chambers? What about direct injection? (Does the BMW use direct injection in the diesels)?
      11-04-2005, 02:21 AM   #8
E90Fleet
South Africa
1312
Originally Posted by Broken1
Thanks
Yes, BMW has been using Direct injction in diesel cars since about 1998. Thats why the piston is shaped so funnely in the middle, to properly distribute the fuel.
What it means is the fuel is injected directly into the cylinder, and not into the air intake manfold just before the valves like the older engines do.
Here is a bit on Common rail technology http://www.swedespeed.com/news/publi...inter_272.html
Your car has 2nd Generation common rail as far as I know
      11-15-2005, 06:17 AM   #9
Dante
Enthusiast
Dante's Avatar
Germany
468
Drives: F87 M2 / F31 330d
That`s why diesel engines are much heavier than petrols (rigid cast, thicker walls) and they take longer to heat up to normal temperature.
You wont notice that since every modern diesel has built in an additional (auxiliary) heater.
My dad had a 2001 530d (navi professional) without the optional auxiliary heater with remote (€ 1200).
A buddy BMW service technician told us, every BMW diesel has the additional heater built in which can be upgraded as fully stand-alone auxiliary heater. And the best:
It was only a software update! Now you can fully operate it from the navi screen, you just have no remote.
So why does the heater cost extra € 1xxx on every BMW, either petrol or not?
      11-16-2005, 05:32 AM   #10
shabs
Drives: VW PASSAT
Dante, I'm curious to know more about this aux heater that's part of all diesel engines, and can just be programmed. I'm getting an E90 diesel in the UK soon, and here they don't offer the aux heating option. (Don't understand why not as it's pretty cold ).
So if it's just a programming issue, could I still get it.
Or is that option dealer fitted? If so, I could get it fitted at a German/Dutch dealer at a later date.
      11-16-2005, 10:30 AM   #11
Dante
Enthusiast
Dante's Avatar
Germany
468
Damn, it really can be cold in the UK (I love travelling London)
Hmm, not sure about e90. Which engine do you get? And are you going to order nav/i-drive? Because if not, I dont know how to operate the aux heater since you have no remote.
But I will talk to my friend over that issue, maybe he knows...
If he confirms I will start a new thread on this.
      12-02-2005, 07:35 PM   #12
rossmelvin
Drives: E90 330i & E60 530i
i love that place too
      03-05-2006, 12:03 PM   #13
krugerjq
South Africa
Drives: X3 2d M Sport, F800GS
The advantage of common rail diesel injection over direct injection is the fact that you have less engine noise and reduces exhaust emissions even further. The diesel engine also has a much higher compression ratio compared to petrol engines. Diesel 17:1 Petrol 11:1. That is why some diesel cars needs oil replacement every 7500 km. Depending of the type of oil they use and the quality of diesel used they push up the service interval. The diesel engine weirs out the oil quicker because of the high compression and the high heat of the turbo charger. That is why the diesel engine oil is always very black, compared to petrol engine oil. It is not good to drive a diesel engine very hard and then just switch it off. You can damage the turbo charger if you do that (all that heat and then no cooling). The turbo also has variable vanes controlled by the engine management system. The BMW 320d is one of the most advanced, most powerful and most economical diesel engines in its size.
      03-06-2006, 11:38 AM   #14
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Diesel is great for burning off/disposing of old dynamite. Just my $.02.
Reply
e90post
