E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > E90 325iSE Flat Spots
Reply
      11-04-2005, 04:23 AM   #1
hdickson
Drives: E90 325iSE
Bought new E90 325iSE in March this year. Noticed a number of flat spots in engine, most noticable at 3200 - 3400rpm. Dealer has updated software a number of times and changed various air filters. Problem still present but BMW (UK) and supplying dealer now claim fault is fixed and refuse to do any further work on car. Dealership principal advised me to look into legal action. If you have the same problem try writing to: -
The Society of Motor Manufacturers and Traders, Forbes House, Halkin Street, LONDON, SW1X 7DS
Problem is to do with VANOS system in engine. Hopefully by writing to their regulatory body in the UK, BMW will admit problem and replace faulty cars. Problems affect most/all 325's, don't let your dealer put you off by saying it is an isolated problem. Check out the web and you will see how widespread the problem is. Good luck!
      11-04-2005, 06:13 AM   #2
David328M-Sport
Australia
101
Drives: F30 M-Sport 328i Estoril Blue
i am pleased to report that my 325 does not seem to have any flat spots. power and torque delivery is terrific.
iam also sorry to read about your problem but unless it is country or production run specific, it doesn't affect all 325 thankfully.
i hope you find a quick resolution to your problem
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      11-04-2005, 07:04 AM   #3
Hornet
Finland
59
Drives: g20 330d xdrive
Arrow
I did a quick search and found this thread: http://www.e90post.com/forums/showth...=325+flat+spot
      11-04-2005, 09:12 AM   #4
saalim
Non Resident
saalim's Avatar
32
Drives: 2006 325i
2006 325i  [0.00]
Very noobish question: What do you mean by a "flat spot"?
Regards
SM
2006 325i | 6MT | Black Sapphire Metallic/Terra Leather/Burl Walnut | ZPP/ZCW | Premium Sound/Navigation/Xenon/PDC/Satellite Radio
      11-04-2005, 12:00 PM   #5
jhbodle
jhbodle's Avatar
146
Drives: F90 M5
My early E90 325i SE had the same problem when I bought it. I knew it was going to be fixed in a software update so I waited until CIP19 was available at my local dealer and booked it in. Took them 2 days, but they fixed the problem completely. The moment I drove it from the workshop, I stuck it in 2nd gear from 2000rpm and floored it all the way past 4000 - seamless and a very big difference to what it was before.
I don't think they've applied the software on your car properly. How long did it take? They should have had it for 2 days.
      11-04-2005, 12:02 PM   #6
jhbodle
jhbodle's Avatar
146
Drives: F90 M5
A flat spot in the rev range is where the engine seems to 'hesitate' for a moment before regaining power and accelerating again, almost as if you have released the accelerator for a split second and then reapplied it.
      11-04-2005, 12:16 PM   #7
MMVI
MMVI's Avatar
Wales
79
Drives: 4 something
I have it..
It is particularly noticeable when the engine is cold.
When accelerating and after about 2.2.5 there seem
like quite a considerable lump in the engine, and then another
one higher up.
I have another fault too. Do you brakes make a continuous tone
most easily heard (obviously when going slow) a bit like a wine glass but sharper.
Has the patch fixed it.
I am going to book mine in.
      11-04-2005, 12:24 PM   #8
jhbodle
jhbodle's Avatar
146
Drives: F90 M5
The hesitation fix is for the one at around 3000rpm. If you have hesitation at around 2000rpm then you may just be lugging the engine...
...but get it booked in at the dealer for the latest CIP update - it fixes the problem.
      11-04-2005, 12:26 PM   #9
jhbodle
jhbodle's Avatar
146
Drives: F90 M5
Oh and by the way - the engine does seem quite weak during break-in...don't worry, it gets much stronger after 1200 miles or so.
My brakes dont make any noise...
      11-06-2005, 02:19 AM   #10
MMVI
MMVI's Avatar
Wales
79
Drives: 4 something
I've checked, it is around the 3000 mark.
      11-06-2005, 09:58 AM   #11
carl_d
carl_d's Avatar
United Kingdom
41
Drives: E90 335i M-Sport N55 6SP Nov10
I also drove a demo 325 in UK before and after new software and the flat spot was done!
      11-06-2005, 10:00 AM   #12
carl_d
carl_d's Avatar
United Kingdom
41
Also, are you all using Shell Optimax 98 RON. Its also makes a big difference.
      11-06-2005, 12:05 PM   #13
jhbodle
jhbodle's Avatar
146
Drives: F90 M5
Carl_d makes a good point. I've only ever used Shell Optimax because its the only petrol in the UK to give the 98RON needed for the car to perform to BMWs specifications.
Reply
e90post
