This MPG is nuts. What should I check out next?
04-26-2012, 11:50 AM | #1 |
resident girl.
59
Rep 1,017
Drives: 2008 335i + 2014 X5
I know there are a lot of "bad gas mileage" threads, so sorry if this has been addressed as I'm sure I wasn't able to read through all of them.
I had a thread going a couple weeks ago about a sudden limp mode/half engine light followed by reduced gas mileage. Took the car in and had both Vanos solenoids replaced under warranty. This fixed the problem for about a week, but it has now returned. I was previously getting around 350-360 miles per tank of gas, and I'm now getting less than 250. So, something is not right. I'm also smelling unburned fuel when I let the car sit for a minute at idle in the driveway. I'd like to avoid another trip to the dealer as it's sort of an ordeal every time, especially if the problem they "fixed" just comes back again in a week. If there are things I could check out myself to at least narrow down the problem I would rather do the work myself, or at least get a solid diagnosis done on my own to be sure the problem(s) is/are being properly addressed. At first I thought the usual coils/injectors/plugs, but I'm not pulling any codes and haven't experienced any misfires, other than a couple of isolated incidents over the past month or two where the car will "balk" very slightly at WOT. I attributed these to driver error, but maybe there's something else to it. Can anyone offer any insight or direction I could take to narrow this down? not quite 42k miles on the odo, Cobb stage 1 Aggressive, 93 octane. Other mods in my sig.
2008 E90 335i // Black Everything // photos COBB tuned / QTP e-cutouts / Helix FMIC / cp-e DCI / AWE BOVs / Catless / FBO + F15 X5 xDrive35i Last edited by cmyk; 04-26-2012 at 04:03 PM.. |
04-26-2012, 11:55 AM | #2 |
Rep 329
You are within the range for gas consumption. My average is a little less then 250 miles per tank. I only have power kit and exhaust on my n55. This is a 3.0 motors with turbo... You can't expect Prius Like consumption.
04-26-2012, 12:06 PM | #4 | |
resident girl.
59
Rep 1,017
My concern is not that the mileage is "bad." My concern is that, within a span of 2 weeks, the gas mileage has dropped nearly in half. You're saying that this wouldn't concern you? ETA: Are you also saying that this, coupled with suddenly smelling strong unburned fuel at idle (that wasn't there previously), is also normal?
2008 E90 335i // Black Everything // photos COBB tuned / QTP e-cutouts / Helix FMIC / cp-e DCI / AWE BOVs / Catless / FBO + F15 X5 xDrive35i |
04-26-2012, 12:10 PM | #5 | |
Rep 299
04-26-2012, 12:21 PM | #6 |
Rep 1,346
Drives: 2011 E92 335 M-Sport
You moded the car, so since the car is probably out of warranty, where have you been getting it serviced? Have you had a COBB tuner look at it?
04-26-2012, 01:29 PM | #7 | ||
resident girl.
59
Rep 1,017
04-26-2012, 01:34 PM | #8 | |
resident girl.
59
Rep 1,017
Having Cobb look at it isn't a bad idea, though. Thanks for the suggestion -- not sure why I didn't think of that.
04-26-2012, 01:56 PM | #10 | |
Rep 299
If the o2 sensors see a rich mixture . you get a cel. You couldnt even smell gas before they would throw a fault. my guess is you got a load of bad gas with either water or to much ethanol in it. Last edited by wobbles1; 04-26-2012 at 02:09 PM.. |
04-26-2012, 02:00 PM | #11 | |
resident girl.
59
Rep 1,017
I'm getting a lot of sarcastic comments, which is fine. Say whatever you want, and call me a stupid girl if it makes you feel better, but if you started noticing abnormal issues in your car that popped up overnight, wouldn't you be at least curious to find out what the potential problem was?
04-26-2012, 02:05 PM | #12 |
Rep 394
Drives: 2008 335i sedan
Check your hoses, clamps, and check valves. You might have a vacuum leak and might be running rich, but not rich enough to set a code if the HEGOs don't detect something wrong.
Bronze
2008 335i sedan | black/black | Sport | Premium |
04-26-2012, 02:08 PM | #13 |
resident girl.
59
Rep 1,017
Thanks
04-26-2012, 02:11 PM | #14 | |
Rep 299
04-26-2012, 02:28 PM | #16 |
resident girl.
59
Rep 1,017
I thought that, and it may be due to the gas station I use regularly. But this has been going on for the past 2-3 tanks of gas, so unlikely.
04-26-2012, 02:51 PM | #17 |
Rep 299
[QUOTE=The car was running beautifully 3 weeks ago. Then I got the Vanos code, had the solenoids replaced, and now this..[/QUOTE]
You answered you own question. as stated before your vanos solenoids were not working properly before you had them changed. This effects valve timing. They were not working properly before. Now they are. That is why you your fuel consumption has changed. IMO. |
04-26-2012, 02:56 PM | #18 |
Retired e90post Member
135
Rep 3,038
you got 350 miles out of 1 tank? that's insane. ive always had about 260 miles out of one at the most... i think you might of had a problem before but i think now youre having the average consumption imo.
04-26-2012, 03:15 PM | #19 | |
resident girl.
59
Rep 1,017
I was averaging 23-ish mpg (combo of city/hwy driving). The Vanos codes popped up, gas mileage went down to ~10, Vanos solenoids replaced, gas mileage back up to 23 for a week or two, now back down to 12-15. So it is what it is, I guess.
04-26-2012, 03:25 PM | #20 | |
Rep 1,274
04-26-2012, 03:31 PM | #21 |
resident girl.
59
Rep 1,017
That statement wasn't directed at you. Your post just happened to be the one I was replying to when I said it.
04-26-2012, 03:45 PM | #22 |
Rep 3,899
I would eat my grandma out to get 250 miles from a tank.
2014 AW F80 M3 DCT
2011 AW E90 M3 DCT - Sold 2010 JZB E90 M3 DCT - Sold 2009 6MT E90 LCI 335i M -Sport - Sold |
