Questions:Recently installed a magnaflow 14815 on my 323I.
04-27-2012, 10:05 AM | #1 |
Rep 285
Hi everyone, i recently installed a magnaflow 14815 on my car, the sound is fairly good. but i think im loss a bit power for my set up on low rpm.. and i find that it is really loud on low rpm.. i dk whether it is normal or not?
my set up like this... my installer use to 90 degree pipe and weld them together to get this set up.. is there anything wrong with it?? my low rpm is really loud.. and why i feel i loss some power for doing this?. thank you. |
04-27-2012, 10:21 AM | #2 |
Rep 611
not enough back pressure will cause loss of low end tq, especially with smaller engine and auto tranny, tq loss will be more sensitive.
also prepare for drone after it breaks in, i had terrible experience with their universal muffler. you should get a full cat back magnaflow system.
N51- PI - PE - ESS Tuned - SSK - CDV Delete - AFE Header - B12 - Mfactory LSD
04-27-2012, 10:41 AM | #3 | |
Rep 221
The back pressure theory is a myth. Our car has many adaptations, one of them being for the lambda (O2) sensors. Drive around for a few hundred miles, the car will adapt to the change. Or you can have a shop, dealer, or someone with access to INPA, or another BMW diag tool, to reset all your adaptations....throttle, octane, knock, lambda, vanos, etc. Btw I have no drone and I also have a 14815 on my n52. And OP, my setup is similar to yours except I cut right behind the resonator and then welded a pipe directly to the res. |
04-27-2012, 11:34 AM | #4 | |
Rep 285
thanks for ur words, i will let it go for a while, and see whats going on..
04-28-2012, 11:56 AM | #7 |
Rep 2,638
others have felt a loss initially after installing a new exhaust but after adaptations it seems to pick back up. how long ago did you install it? Pictures of the finished product?
04-29-2012, 03:50 PM | #8 |
Rep 285
02-17-2013, 01:57 AM | #9 |
Rep 2,638
As a follow up. I put my aftermarket exhaust on the Dyno. I thought I had lost torque and power but I had gained in both. I think the added noise and the fact that you aren't really speeding up plays tricks with the mind.
