water in trunk
04-27-2012, 04:13 PM | #1 |
Rep 994
water in trunk
odd problem with the e93. driving around yesterday and i heard water sloshing around when i would come to a stop. i open the trunk, and there is water in the battery compartment and the carpeting on the right side where the bracket is for where the top rests when it's retracted. there was no water on any of the rubber seals and no water under the rear deck lid or any other indication that water was dripping down. we did have heavy rains for a few days and i did drive through some pooled water at 40-50 mph. any ideas?
iPhone 6 Plus (iTunes library/iTunes radio/Waze, etc) to Airport Express via AirPlay. Toslink out of Airport Express to Helix P-Six DSP. PHD AF 1.C tweeters, PHD FB 4.1 midranges. Jehnert Door Cards and mid-bass'.
04-27-2012, 04:42 PM | #2 |
Rep 600
I bet your seal around the whale tail (SAT antenna) is leaking. You may check that...saw a post around here some time ago where someone ordered a replacement seal for that for this very reason - water in the trunk. Good luck!
Jay (in San Antonio, TX)
2014 428i coupe, mineral gray metallic with black interior, black ash trim, luxury edition. |
04-27-2012, 04:51 PM | #3 |
Rep 1,086
Drives: '11 335i M-Sport [LeMans Blue]
Similar thing happened to my Z4, and as a result the insurance company totaled the vehicle as the electronics were fried and risk of mold.
My was a result of water coming down through the softtop as the pathways for the water to clear were clogged and overfilled.
'11 335i M-Sport xDrive Coupe [LMB] COBB V3 & PTF Tune | E45 |4in BERK DP | VRSF 5in FMIC | BMS Intake | ER CP | Exotics Tuning CF Lip | CF Diffuser | Eibach Springs | Bilstein Shocks '07 BMW 335i Coupe & BMW Z4 3.0i - Gone |
04-27-2012, 04:57 PM | #4 |
Cisco661
61
Rep 974
Drives: 2006 Monaco Blue 330I
i would place some towles along inside of trunk then close it and run a water hose around it for a minute. when you open the trunk look for wet spots on the towel to determine where its leaking. hope dont know if it will work but hope it helps..
2006 330i/ Monaco Blue/ ZSP/ ZPP/ I Drive/ Burl Walnut Trim/ Steptronic/ Xenon Adaptives/ Logic7/ CF Mirror Caps/ Matte Black Grills
04-27-2012, 05:07 PM | #5 |
Rep 994
I hears swooshing just now while driving and it sounded like the passenger side rear window compartment. Rolled windows down and back up, window coated with water. Other windows remain dry.
04-27-2012, 06:38 PM | #8 |
Cisco661
61
Rep 974
wow its worse than i thought. good luck. im sure theres damage to the window motor and more. you still under warranty?
04-28-2012, 02:44 AM | #9 | |
The Logistician
69
Rep 799
Drives: 2022 230i M-Sport
